Posted 14 September 2017, 11:29 am EST
I am using data-map attribute in flexgrid column to show dropdown values. However, I notice the dropdown height is fixed to 128px.
How do I adjust the height of the dropdown?
Thanks & Regards,
Rus
Posted by: apacbi on 14 September 2017, 11:29 am EST
Thanks & Regards,
Rus
The “max-height” css attribute of the DataMap dropdown list has been set to 128px. You can reset the max-height and height of the dropdown list by using the following css:
[style]
.wj-listbox{ max-height: 300px; height:200px; }
[/style]
Kindly refer to the attached HTML Page which implements the same. Hope it helps.
Manpreet Kaur
2016/01/DataMapHeight.html
Hi Manpreet,
With the css you provided, it is still showing as 128px (see attached css inspector).
Thanks & Regards,
Rus
You can use the following css to change the height and max-height of the dropdown list:
[style]
.wj-listbox{ max-height: 300px!important; height:200px; }
[/style]
Manpreet Kaur
2016/01/NDataMapHeight.html
Hi Manpreet,
It works now, thanks!
Rus
Posted 27 November 2019, 1:36 pm EST - Updated 3 October 2022, 6:41 pm EST
Manpreet,
I have tried following all the steps in this thread, but my DataMap is stuck at 80px height.
I have attached screenshots of my CSS and web inspector. Can you advise on how to get around the 80px height limitation?
Jean
CSS:
DataMap Dropdown height stuck at 80px:
Inspector confirms that max-height is limited to 80px despite above CSS:
Posted 27 November 2019, 11:41 pm EST
Hi Jean,
Could you please try using the following CSS rules:
.wj-dropdown-panel.wj-grid-listbox.wj-control.wj-content.wj-listbox {
max-height: 500px !important;
height: 300px !important;
Please refer to the sample link below for reference:
https://stackblitz.com/edit/js-fkbtaa
