Align data inside cell based on the columns' dataType in FlexGrid
Posted by: sskss1ss2 on 20 July 2023, 5:01 am EST
  • Posted 20 July 2023, 5:01 am EST
    Iam using wijmo FlexGrid to render a table data. Based on the datatype of the column header i want to align the data inside each each cell. ForEg: if its a boolean then center aligned or if its a number than left aligned.
    Currently Iam using the ItemFormatter to align each and every cell. But this is very expensive. Can it be done in a different way other than using itemFormatter?
  • Posted 21 July 2023, 11:14 am EST
    You may use align property of Column class to set alignment of the columns. To know the dataType of the column, use the dataType property of Column class.
    Please refer to this sample for reference: https://stackblitz.com/edit/js-nnafkg
    Please refer to the following API references for more information on align and dataType property of Column class:
    1. align: https://www.grapecity.com/wijmo/api/classes/wijmo_grid.column.html#align
    2. dataType: https://www.grapecity.com/wijmo/api/classes/wijmo_grid.column.html#datatype
  • Posted 23 July 2023, 11:11 pm EST
    But the above implementation i’ve done it already making use of itemFormatter builtin function. Iam trying to avoid the usage of itemFormatter. Can we do it without using it?
  • Posted 24 July 2023, 12:57 am EST
    You may do the same without using the itemFormatter. Use the loadedRows event of FlexGrid to assign the alignment for the desired column. Please refer to the following code snippet:
    let alignment = {
      Number: 'left',
      Boolean: 'center',
      String: 'right',
    let grid = new FlexGrid('#gridHost', {
      loadedRows: (sender, args) => {
        let columns = sender.columns;
        for (let index = 0; index < columns.length; index++) {
          // Set the align property of the column as per dataType.
          columns[index].align = alignment[DataType[columns[index].dataType]];
      itemsSource: getData(12),
    You can also refer to this sample for reference: https://stackblitz.com/edit/js-op7kmf
  • Posted 24 July 2023, 1:51 am EST
    I tried doing the above, the dataType is coming as null even when i have the column information.
  • Posted 24 July 2023, 7:04 am EST
    As, we are not able to replicate the behavior on our end so please share a small working sample replicating the issue. This will help us to assist you better as per your use case.
    You can even modify this sample to replicate the issue: https://stackblitz.com/edit/js-prnjyw
