Arranging the data alphabetically in wijmo listbox
Posted by: nivishapanwar on 10 February 2021, 10:37 am EST
    Posted 10 February 2021, 10:37 am EST
    How can we arrange the data in listbox alphabetically on selection of radio button. Using typescript code.
    Nivisha Panwar
  • Posted 12 February 2021, 4:01 am EST
    Hi Nivisha,
    You may add SortDesription object to the collectionView.sortDescriptions collection to sort the data. You May refer to the following sample demonstrating the same:
    https://codesandbox.io/s/wijmo-angular-forked-yjn5r?file=/src/app/app.component.ts
    Sharad
  • Posted 15 February 2021, 10:47 am EST
    Hi Sharad,
    I tried with the same logic, but it didnt work for me.
    this.name = new CollectionView(this.recordData);
    rChange(val) {
    //let cv = this.ListData.collectionView;
    if (val) {
    this.name.sortDescriptions.push(new wjCore.SortDescription(null, true));
    } else {
    this.name.sortDescriptions.clear();
    <wj-list-box #ListData [itemsSource]=“name”
    (selectedIndexChanged)=“displayListBoxValueInTextField(ListData)”>
    Alphabetical Logical
    Does the soln doesnt work for dynamic data? Thank you, Nivisha
  • Posted 16 February 2021, 2:05 pm EST
    Hi Nivisha,
    The solution is supposed to work with dynamic data too. Please explain about the issue you are facing and share a sample that replicates the issue so that we could further investigate it and assist you accordingly.
    Sharad
  • Posted 19 February 2021, 10:43 am EST
    Hello Sharad,
    The issue is when I choose alphatical radio box , the data is not getting sorted.
    rChange(val) {
    if (val) {
    } else {
    Thank you. Regards, Nivisha
  • Posted 23 February 2021, 4:33 am EST
    Hi Nivisha,
    Nothing in the code snippet seems out of ordinary. Please share a sample that replicates the issue so that we could further investigate it and assist you accordingly.
    Sharad
  • Posted 24 February 2021, 2:09 am EST
    Hi Sharad,
    Thank you for the help. It’s working fine now.
    Nivisha
