Auto testing for column moving/re-ordering in UI
Posted by: kamlesh_patel on 2 August 2023, 10:49 am EST
    Posted 2 August 2023, 10:49 am EST - Updated 2 August 2023, 10:51 am EST
    Hi Team,
    We are developing an automated test for the Wijmo grid control in C# and using the Selenium driver where we intend to move/re-order the column in the UI but it’s not working, we are using the Selenium Actions as in the code below, Please refer to the code below.
    Has anyone implemented autotests for the Wijmo? Please let us know the code reference on how it can be done in if there is a working example.
    new Actions(Driver)
        .DragAndDrop(columns[2], columns[8])
        .Build()
        .Perform();
    or
    new Actions(Driver)
        .ClickAndHold(columns[2])
        .MoveToElement(columns[8])
        .Release(columns[2])
        .Build()
        .Perform();
  • Posted 3 August 2023, 5:34 am EST
    To perform drag and drop operation on FlexGrid you can use the below shared code snippet:
    public static void DragDropOperation(this IWebDriver driver, IWebElement sourceElement, IWebElement targetElement, string position = "center center", bool shouldPerformDrop = true)
    			var pos = position.Split(' ');
    			string horizontalDelta = "", verticalDelta = "";
                switch (pos[0])
    				case "top": horizontalDelta = "targetCoordinates.width * 0.25"; break;
    				case "bottom": horizontalDelta = "targetCoordinates.width * 0.75"; break;
    				default: horizontalDelta = "targetCoordinates.width * 0.5"; break;
    			switch (pos[1])
    				case "top": verticalDelta = "targetCoordinates.height * 0.25"; break;
    				case "bottom": verticalDelta = "targetCoordinates.height * 0.75"; break;
    				default: verticalDelta = "targetCoordinates.height * 0.5"; break;
    			var dropScript = $@"
    				function completeDrag(){{
    					// simulate a drop event on the target element
    					var dropEvent = createEvent(
    						""drop"",
    							clientX: targetCoordinates.left + {horizontalDelta},
                                clientY: targetCoordinates.top + {verticalDelta},
                                dataTransfer: dragStartEvent.dataTransfer
    					targetElement.dispatchEvent(dropEvent);
    					// simulate a drag end event on the source element
    					var dragEndEvent = createEvent(
    						""dragend"",
    					 sourceElement.dispatchEvent(dragEndEvent);
    					// simulate a mouseup event on the target element
    					var mouseUpEvent = createEvent(
    						""mouseup"",
    					targetElement.dispatchEvent(mouseUpEvent);
    				function cancelDrag(){{
    						""dragend"",
    							clientX: sourceCoordinates.left + sourceCoordinates.width / 2,
                                clientY: sourceCoordinates.top + sourceCoordinates.height / 2,
    			var script = $@"
    				var CustomDataTransfer = function () {{
                        this.data = {{}};
                    CustomDataTransfer.prototype.dropEffect = ""move"";
    				CustomDataTransfer.prototype.items = [];
    				CustomDataTransfer.prototype.types = [];
    				CustomDataTransfer.prototype.clearData = function(format) {{
    					if (format)
    						delete this.data[format];
    						var index = this.types.indexOf(format);
    						if (index > -1)
    							delete this.types[index];
    							delete this.data[index];
    					else
    						this.data = {{ }};
    				CustomDataTransfer.prototype.setData = function(format, data) {{
    					this.data[format] = data;
    					this.items.push(data);
    					this.types.push(format);
    				CustomDataTransfer.prototype.getData = function(format) {{
    					if (format in this.data) {{
    						return this.data[format];
    					return """";
    				function createEvent(eventName, options)
    					var event = document.createEvent(""CustomEvent"");
                        event.initCustomEvent(eventName, true, true, null);
    					event.view = window;
    					event.detail = 0;
    					event.ctlrKey = false;
    					event.altKey = false;
    					event.shiftKey = false;
    					event.metaKey = false;
    					event.button = 0;
    					event.relatedTarget = null;
    					// if the clientX and clientY options are specified,
    					// also calculated the screenX and screenY values
    					if(options.clientX && options.clientY) {{
    						event.screenX = window.screenX + options.clientX;
    						event.screenY = window.screenY + options.clientY;
                        // copy the rest of the options into the event object
                        for (var prop in options) {{
                            event[prop] = options [prop];
                        return event;
    				function executeDragAndDrop(sourceElement, targetElement)
    					if (typeof sourceElement == ""string"")
    						sourceElement = document.querySelector(sourceElement);
    					if (typeof targetElement == ""string"")
    						targetElement = document.querySelector(targetElement);
    					// get the coordinates of both elements,
    					// left refers to X, and top to Y
    					var sourceCoordinates = sourceElement.getBoundingClientRect();
    					var targetCoordinates = targetElement.getBoundingClientRect();
    					// simulate a mouse down event on the coordinates of the source element
    					var mouseDownEvent = createEvent(
    						""mousedown"",
    					sourceElement.dispatchEvent(mouseDownEvent);
    					// simulate a drag start event on the source element
    					var dragStartEvent = createEvent(
    						""dragstart"",
                                dataTransfer: new CustomDataTransfer()
    					 sourceElement.dispatchEvent(dragStartEvent);
    					// simulate a drag event on the source element
    					var dragEvent = createEvent(
    						""drag"",
    					sourceElement.dispatchEvent(dragEvent);
    					// simulate a drag enter event on the target element
    					var dragEnterEvent = createEvent(
    						""dragenter"",
    					targetElement.dispatchEvent(dragEnterEvent);
    					// simulate a drag over event on the target element
    					var dragOverEvent = createEvent(
    						""dragover"",
    					targetElement.dispatchEvent(dragOverEvent);
    					{dropScript}
    					{(shouldPerformDrop? "completeDrag();" : "window['completeDrag'] = completeDrag;window['cancelDrag'] = cancelDrag;")}
    			executeDragAndDrop(arguments[0], arguments[1]);
    			((IJavaScriptExecutor)driver).ExecuteScript(script, sourceElement, targetElement);
    			driver.Wait(TimeSpan.FromMilliseconds(500));
    // In the following code snippet:
    // 'sourceElement' represents the columnHeader cell element of the source column,
    // 'targetElement' represents the columnHeader cell element of the target column (where to drop).
    Selenium’s DragAndDrop or MoveToElement methods do not work as expected due to some events not being triggered in the required order by Selenium. To address this, you can execute the above script to perform the drag and drop operation. If you encounter any difficulties, please feel free to inform us, and we will be glad to assist you.
  • Posted 3 August 2023, 9:51 am EST
    Thank you for the quick reply.
    The shared code snippet has worked for us.
