Posted 25 July 2018, 2:51 pm EST
- Bubbles chart axes ranges are not adjusted and bubbles get clipped
- Bubble size calculated incorrectly if chart contains extra line series (for ex. trend line)
Please see an attached html sample.
Posted by: azhigimont on 25 July 2018, 2:51 pm EST
Posted 28 July 2018, 9:21 am EST
Chart calculates the range of axis based on the min and max values present in the series. In most of the cases it calculates the series size most efficiently however in some case like this one the values calculated by chart is not sufficient so we would have to assign the appropriate min, max values ourselves.
We were able to replicate the issue at our end and hence it has been forwarded to the concerned team.
Thanks for reporting this…
~Manish
Posted 30 July 2018, 1:25 pm EST
Hi Manish,
Thanks for your quick reply!
What’s the verdict on the item 1?
Are you forwarding it to your team, too?
-Alex
Posted 1 August 2018, 11:51 pm EST
We are sorry for the delayed response.
We have also escalated this case to the concerned team with tracking id 336715. We will let you know for any updates.
Till then you may refer to the attached sample for the workaround.
~Manish
BubbleWorkaround.zip
Posted 15 February 2019, 6:27 pm EST
Any update on tracking id 336715?
Posted 18 February 2019, 2:00 am EST
The issue is fixed in the latest release 5.20183.568.
You may confirm the same from the following sample which uses the specified build:
https://stackblitz.com/edit/js-zqtthx?file=index.js
Posted 19 February 2019, 4:34 pm EST
Hmm, the latest version I’m able to download is 5.20183.550
Where do I get 568?
Also, the issue still happens in the provided example (try to refresh several times).
Posted 20 February 2019, 8:29 am EST
Hi Alex,
Yes, you are right. Upon further investigation, we could observe that the issue is still reproducible in some scenarios hence we have reported it back to the dev team. We will let you know as we get an update.
We apologize for the inconvenience caused.
Posted 19 November 2019, 5:38 am EST
The calculation for axis limits for Bubble chart has been improved in the latest build “5.20193.637”. Please refer to the following updated sample:
https://stackblitz.com/edit/js-mpwywb?file=index.js
PS: Please notice that it isn’t always possible to avoid clipping, especially when the chart size is small.
Manish Gupta
