Bug in export flexGrid to xlsx
Posted by: arq2002 on 15 July 2022, 11:17 am EST
  • Posted 15 July 2022, 11:17 am EST
    When flexGrid has both rows and columns frozen, then after export to excel, only frozen rows appear in excel.
    The bug is in file @grapecity\wijmo.xlsx\index.js
     _xlsx._generateSheetGlobalSetting = function(e, t, o) {
            var r = t.rows && t.rows[0] && t.rows[0].cells ? t.rows[0].cells.length : 0,
                l = ' xmlns:r="http://schemas.openxmlformats.org/officeDocument/2006/relationships"';
            this._sheetHasNotes(e) && (l += ' xmlns:xdr="http://schemas.openxmlformats.org/drawingml/2006/spreadsheetDrawing" xmlns:x14="http://schemas.microsoft.com/office/spreadsheetml/2009/9/main"');
            l += ' xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006" mc:Ignorable="x14ac" xmlns:x14ac="http://schemas.microsoft.com/office/spreadsheetml/2009/9/ac">';
            l += '<sheetPr><outlinePr summaryBelow="0"/></sheetPr>';
            l += '<dimension ref="A1' + (r > 0 ? ":" + this._numAlpha(r - 1) + t.rows.length : "") + '"/>';
            l += '<sheetViews><sheetView workbookViewId="0"';
            e === o.activeWorksheet && (l += ' tabSelected="1"');
            var i = 0,
                s = 0;
            if (t.frozenPane && ((i = t.frozenPane.rows || 0) | (s = t.frozenPane.columns || 0))) {
                l += ">";
                l += '<pane state="frozen" activePane="' + (0 !== i && 0 !== s ? "bottomRight" : 0 !== i ? "bottomLeft" : "topRight") + '" topLeftCell="' + (this._numAlpha(s) + (i + 1)) + '" ySplit="' + i.toString() + '" xSplit="' + s.toString() + '"/>';
                l += "</sheetView>"
            } else l += "/>";
            l += "</sheetViews>";
            return l += '<sheetFormatPr defaultRowHeight="15" x14ac:dyDescent="0.25"/>'
    see line:
     if (t.frozenPane && ((i = t.frozenPane.rows || 0) || (s = t.frozenPane.columns || 0)))
    should be:
    becouse when t.frozenPane.rows != 0 then s is not set.
    Second bug is when in export options we ommited some frozen columns, eg:
    grid.frozenColumns = 4;
    var options =
                includeColumnHeaders: true,
                formatItem: exportFormatItem,
                includeColumns: function (column) { return column.index !== 1 && column.index !== 3; }
  • Posted 15 July 2022, 11:44 am EST
    Sorry, should be:
     if (t.frozenPane && ((i = t.frozenPane.rows || 0) || (s = t.frozenPane.columns || 0))) {
    s = t.frozenPane.columns;    //  <-- again becouse s is not set
  • Posted 19 July 2022, 6:48 am EST
    Thank you for reporting the issue. We are able to replicate both the issues and hence we have escalated it to the dev team for further investigation(WJM-24491). We will keep posting updates on this thread.
    Sharad
