Bullet graph custom tool tip option
Posted by: abhatt on 21 April 2020, 12:27 pm EST
    Posted 21 April 2020, 12:27 pm EST
    In the bullet graph when i try to create custom tooltip to view specific information, it does not show any tool tip. I have used the below mentioned demo to creating the code. In the documentation related to Bullet Graph Gauge could not find any other information related to it.
    https://www.grapecity.com/wijmo/demos/Chart/Features/CustomTooltips#
    Aishwariya
  • Posted 22 April 2020, 1:32 am EST
    Hi Aishwariya,
    The bullet graph is not a type of FlexChart, instead it is a type Gauge. Therefore, the Chart tooltip sample will not work in this case. In order to add tooltip on the bullet graph, you can create a new instance of the Tooltip class and use it’s setTooltip method add tooltip on the hostElement of the bullet graph.
    https://stackblitz.com/edit/js-6jzdsr
  • Posted 22 April 2020, 4:20 am EST
    Hello Ashwin,
    The code demo in the response is related to javascript, could you show the same using react. In the react code i am able to set the tooltip method and display the tool tip but cant access the bullet graph value and display it in the tooltip using react.
  • Posted 23 April 2020, 1:06 am EST
    Please refer to the updated sample below:
    https://stackblitz.com/edit/react-c5jger
    In this sample, to add a tooltip, I have used the initialized event of the Bullet graph and provided the item in the event. Then, I used the bullet graphs’ instance and the item provided to create a tooltip.
  • Posted 23 April 2020, 5:16 pm EST
    Thank You for the response.
    Aishwariya
