Calling a function inside an addEventListener in an itemFormatter function
Posted by: david.hettmer on 28 July 2021, 3:04 pm EST
  • Posted 28 July 2021, 3:04 pm EST
    Hi, i am working on a wijmo grid header checkbox to to trigger a function when clicked. the checkbox was generated via innerHTML called from an itemFormatter. below is the code
    i tried calling it like this
    cb.addEventListener('click', () => {
      flex.beginUpdate();
      for (let i = 0; i < flex.rows.length; i++) {
        flex.setCellData(i, c, cb.checked);
      flex.endUpdate();
      this.updateInvoiceData.bind(this);
    but it seems like it’s not calling the function.
    i tried decalring the this in to a variable and still not worked, I also tried using time out but it is still not working. Is there a work around for this to work or did i missed out any on the approach I was attempting to resolve the issue?
  • Posted 29 July 2021, 5:28 am EST
    In the provided code snippet, We could observe that updateInvoiceData() is invoked with bind() but not called after binding the reference. bind() returns a new function. So We need to call the returned function after binding reference with bind() as follows -
     cb.addEventListener('click', e => {
              flex.beginUpdate();
              flex.endUpdate();
              let update = this.updateInvoiceData.bind(this, 'test');
              update();
    For better understanding, you may refer to the below code sample -
    https://stackblitz.com/edit/angular-y6ohkr?file=src%2Fapp%2Fapp.component.ts
  • Posted 29 July 2021, 9:01 am EST
    Hi, I tried your resolution, but i got an error
    Uncaught TypeError: Cannot read property 'bind' of undefined
    i also followed the same approach from the stacblitz link you attached
  • Posted 30 July 2021, 7:29 am EST
    From the provided error message it seems like the method that you are invoking with bind() is not available. Please make sure that the method that you are invoking with bind() is available.
    Moreover, would you please clarify if you are observing this error message in the provided stackblitz sample too? If not, Kindly provide us a code sample that demonstrates the issue so that we could further investigate the issue and assist you accordingly
  • Posted 30 July 2021, 1:36 pm EST
    Yes. It is also happening with the stakcblitz you attached, below is the code being called from the gird’s itemformatter
       * @description
       *  Formats each cell upon update events. Called by flexgrid... all the time.
       *  Notably this function adds checkboxes to the first column rows and header
       * @param panel - flexgrid panel
       * @param r - row index
       * @param c - column index
       * @param cell - current flexgrid cell
      public itemFormatter(panel: GridPanel, r: number, c: number, cell: any) {
        // add checkbox to header, sync with checkboxes in column
        if (panel.cellType === CellType.ColumnHeader) {
          const flex = panel.grid;
          const col = flex.columns[c];
          // check that this is a boolean column
          if (col.dataType === DataType.Boolean && c === 0 && r === 0) {
            // prevent sorting on click
            col.allowSorting = false;
              const intialCheck = flex.getCellData(i, c, false);
              if (typeof intialCheck === 'undefined') {
                flex.setCellData(i, c, false);
            // count true values to initialize checkbox
            let cnt = 0;
              if (flex.getCellData(i, c, false) === true) {
                cnt++;
            // create and initialize checkbox
            cell.innerHTML = '<input type="checkbox" style="height: 13px !important;">';
            const cb = cell.firstChild;
            cb.checked = cnt > 0;
            cb.indeterminate = cnt > 0 && cnt < flex.rows.length;
            // apply checkbox value to cells
              flex.beginUpdate();
              flex.endUpdate();
              const update = this.updateInvoiceData.bind(this);
              update();
  • Posted 2 August 2021, 2:36 am EST
    Please try changing the itemFormatter function to arrow function like:
    public itemFormatter = (panel: GridPanel, r: number, c: number, cell: any) => {
    // TODO
    If the issue persists, please share a small working sample replicating the issue so that we could investigate the root cause of the issue and assist you accordingly.
