Cannot use drag/drop between GroupPanel and FlexGrid that uses column groups
Posted by: matt_baker on 2 November 2020, 3:26 pm EST
    Posted 2 November 2020, 3:26 pm EST
    I need to be able to use the GroupPanel with a FlexGrid that has grouped columns. Right now the drag/drop is broken for columns with no sub-columns (which is my use case).
    See attached ZIP of modified demo from https://www.grapecity.com/wijmo/demos/Grid/Columns/ColumnGroups/purejs. The simple columns like “Name” should be group able with the GroupPanel. You can manually set the groupings via the grid’s collectionview. But the drag/drop functionality is missing.
    Is there a solution or workaround to get non-grouped columns (columns with no sub-columns underneath) to be group able using the GroupPanel.
    Grid_Columns_ColumnGroups_JavaScript.zip
  • Posted 3 November 2020, 2:36 am EST
    Hi Matt,
    I have replied to your query on the support one portal. For reference, I am pasting the response here also:
    Whenever column groups are created, the columns are not draggable by default. You can change this by setting the allowDragging property of the columns to true after creating the FlexGrid:
    theGrid.columns.forEach(c => c.allowDragging = true);
    You can refer to the sample attached.
    dragging.zip
