Cant edit cell when childItemsPath has multiple Trees
Posted by: viethdhe130200 on 1 December 2021, 6:33 am EST
  • Posted 1 December 2021, 6:33 am EST
    setRowReadOnly = row => {
    if(…) {
    row.isReadOnly = false
    } else {
    row.isReadOnly = true
    <FlexGird
    childItemsPath={[‘array1’, 'array2 ]}
    My problem that I can edit when use two or more tree in childItemsPath . If I use childItemsPAth={array}, it’ll work .
    So, I need some help. Thank you.
    p/s: I code react js
  • Posted 2 December 2021, 7:05 am EST
    We apologize but we are unable to replicate the issue at our end, would you please clarify if you are facing the issue with the shared sample below too? If yes, please share some screenshots/gif of the exact issue. If you are facing this issue only in your application but not in the shared sample then it is possible that the issue is arising due to some code specific to your application. Since we are unable to replicate the issue, I would request you to share a sample that demonstrates the issue so that we could further investigate the root cause of the issue and assist you accordingly. Without a sample to replicate the issue, we cannot comment on the actual nature of the issue.
    Sample link: https://jscodemine.grapecity.com/share/e7D-DXSBxkGUFdrN7CttNg/
  • Posted 6 December 2021, 4:45 am EST
    Thank you for answer. I did it.
