Cell Click Event does not fire when Detail View is open
Posted by: viplav.setia on 9 September 2021, 7:55 am EST
    Posted 9 September 2021, 7:55 am EST - Updated 3 October 2022, 12:33 pm EST
    Hello Support Team
    We are using the Master Detail view of the FlexGrid. We have some buttons in a few columns of the master grid which do not fire when the Detail view is open. See picture attached.
    Is there a setting or a workaround available here?
  • Posted 10 September 2021, 4:50 am EST
    Sorry, but we are unable to replicate the issue at our end. Could you please provide some more information on the following:
    1. how you are adding the buttons to the master grid?
    2. when you are adding a click event to the buttons?
    Also, if possible could you please provide some more a sample replicating the issue? I have prepared a sample, you can refer to the sample to see if your approach is different from the ones I have used, feel free to modify the sample to replicate the issue and send us back so that we can assist you better.
    sample link:https://stackblitz.com/edit/js-r7skrr?file=index.js
  • Posted 10 September 2021, 7:28 am EST
    Hello Sonu
    Thank you for the quick reply. You can close this ticket. I found the cause. We use a Bridge to convert C# code to javascript and the C# object could not pick up the cell object defined in the wijmo javascript function.
