Cell Edit Template does not work with ChangeDetectionStrategy.OnPush
Posted by: igor on 27 June 2019, 10:50 am EST
    Posted 27 June 2019, 10:50 am EST
    When upgrading to the latest version of Wijmo I have noticed that my cell edit templates have stopped working. They render vanilla HTML markup but not Angular syntax.
    After some investigation, I’ve found out that if I switch the ChangeDetectionStrategy from OnPush to Default, it gets fixed, but that is a change I cannot afford on certain large grids.
    A similar problem has been reported before on https://www.grapecity.com/forums/wijmo/flex-grid---issue-in-displ_2 but the posted workaround did not work.
    Here is a minimal repro with the workaround applied but not working: https://stackblitz.com/edit/angular-vsusht
  • Posted 28 June 2019, 3:15 am EST
    Could you please try using the beginningEdit event instead of updatedView event:
      init(grid) {
        grid.beginningEdit.addHandler(() => this.cdRef.markForCheck())
    You may refer to the updated sample below:
    https://stackblitz.com/edit/angular-ut3gcr
    Please tell us whether this solution solves your issue.
  • Posted 2 July 2019, 12:21 pm EST - Updated 3 October 2022, 3:11 pm EST
    Yes, that works. That will allow me to keep working on the upgrade. Do you guys have a plan/timeline to fix it?
    Thanks!
  • Posted 3 July 2019, 6:57 am EST
    Could you please let us know which wijmo version were you using before in which the issue did not exist so that I can pass this information to the dev team.
  • Posted 3 July 2019, 10:26 am EST
    I was at 20171.293.
    Thank you!
  • Posted 4 July 2019, 1:50 am EST
    We have forwarded a bug report for the same with internal tracking id 387385. We will give you an update as soon as the issue is fixed.
  • Posted 29 July 2019, 4:00 am EST
    Hi Igor,
    The issue has been fixed in the latest nightly build of Wijmo. You may verify the same using the sample below:
    https://stackblitz.com/edit/angular-pcfv3x
    PS: Nightly builds have not passed through the QA cycle as our release builds do. So, they are not suitable in the production environment.
