Posted 16 August 2021, 5:59 pm EST - Updated 3 October 2022, 12:46 pm EST
Change group header style in Flexgrid
Posted by: omarovd on 16 August 2021, 5:59 pm EST
Posted 17 August 2021, 7:15 am EST
As per my observation from your screenshot, you are using the Hierarchical Data representation FlexGrid and the group rows are the parent rows, if that’s the case then
We are unable to replicate your issue for adding cssClassAll, we have added the cssClassAll to the first column in the sample attached, please refer to the sample link given below:
https://stackblitz.com/edit/react-b3ljvh?file=index.js
Also, you can easily apply the CSS to only the parent group row like:
.wj-row[aria-level='1'] .wj-cell { background-color: rgb(247, 222, 0) !important; }
As you are using the hierarchal data the cell merging wouldn’t work, you need to manually merge the cells by firstly removing the data from the other cells on that group row.
If you are using the group row by setting the group description of the CollectionView, then
You can use the .wj-cell.wj-group class to add styling to the group rows. Please refer to the code snippet below:
.wj-cell.wj-group{ background-color: red; }
You don’t need to merge the cells as group rows would be already merged as you required.
If you are using any other approach then please do let us know the following points:
- How are you adding the group rows?
- How are you adding the cssClassAll and where?
If possible could you please provide a sample depicting your issue?
Ashwin -
Posted 17 August 2021, 9:53 am EST
Hello Ashwin,
Thanks a lot for the quick answer.
The way with ```
.wj-row[aria-level=‘1’] .wj-cell
