Chart will be cut off when the legend and title and axes are turned off
Posted by: Yifan_Zhang on 12 October 2020, 2:42 am EST
  • Posted 12 October 2020, 2:42 am EST
    See the example here: https://jsfiddle.net/4b1zcx2y/
    The scatter points at the edge will be cut off and the actual wj-series-group is not the same size as the svg.
  • Posted 13 October 2020, 3:50 am EST
    Hi Yifan,
    Thanks for reporting the issue. I have forwarded this to the developers with internal tracking id 467000. I will update you once I will hear from them.
    As a workaround, you can increase the margin of the FlexChart using the plotMargin property so that there is extra space displayed from all the sides and the points are not cut off.
    https://jsfiddle.net/b8wpf346/16/
  • Posted 16 October 2020, 1:13 pm EST
    Thanks for the workaround. Looking forward to the genuine fix.
  • Posted 27 October 2020, 10:11 am EST
    Hi Yifan,
    The issue has been fixed in the latest nightly build of Wijmo. You can verify by installing the nightly version of Wijmo from NPM.
    Note that nightly builds have not been passed through the QA cycles and are not suitable for production environment.
  • Posted 18 November 2020, 4:26 am EST
    Hi Yifan,
    The fix is added to the latest version of Wijmo (5.20203.748). Please upgrade to this version to resolve this issue.
    Let us know in case you run into issues while upgrading.
