CollectionView.addNew() FlexGrid scrolling bug
Posted by: abnviera on 12 September 2021, 6:08 pm EST
    Posted 12 September 2021, 6:08 pm EST
    Hi.
    I’m using Wijmo FlexGrid with Vue2 and Bootstrap 4.
    The FlexGrid is linked to a CollectionView. So when I use CollectionView.addNew method, the item is added succesfully to FlexGrid, but grid moves the scroll incorrectly if the item is added at the end of the grid with vertical scrollbar.
    I think the method scrolls to the end minus row size.
    Image asset:
    https://ibb.co/qxkRZrx
  • Posted 13 September 2021, 9:29 am EST
    We apologize, but we are unable to replicate the issue at our end. Could you please provide a sample replicating the issue?
    As per our understanding, the issue might occur because of some styling, so investigating the sample would help us to help you better.
  • Posted 15 September 2021, 9:55 pm EST
    Here is a sample of the issue: https://jsfiddle.net/pkrzwd4y/
    The issue appears when the last row is selected then add new item using function addNew().
    Regards.
  • Posted 16 September 2021, 4:44 am EST
    This seems to be a bug, we have escalated the issue to the Dev team for further investigation with an internal tracking id WJM-20914. We will let you know as soon as we get any updates on this.
    Meanwhile, as a workaround, you can call the scrollIntoView method of FlexGrid on collectionChannged event of CollectionView to set the last added item into the view range. Please refer to the sample link below demonstration the same:
    https://jsfiddle.net/0upvd7sc/2/
    Sonu Kumar Pandey
  • Posted 16 September 2021, 10:26 pm EST
    Thanks for understanding. I am going to implement scrollIntoView.
