ColumnGroups with wj-flex-grid-column
Posted by: tim_bendon on 29 September 2020, 6:14 am EST
  • Posted 29 September 2020, 6:14 am EST
    Is there any support for defining column groups within the angular template? e.g. I would like to do something like:
    I have seen the Angular examples for adding column groups via wj-flex-grid but this doesn’t work well when using ng-template in the template within a wj-flex-grid-column to specialise the display for a particular column.
  • Posted 30 September 2020, 7:22 am EST
    Hello Tim,
    As we understand, you would like to define the column groups using tags the same as WjFlexGridColumn.
    Currently, this is not supported and it has been forwarded to the concerned team for further investigation with internal tracking id: 441882.
    We will let you know as we get an update on this.
    Manish Gupta
