columnHeaders extra row with existing nested columns
Posted by: amakarenko on 7 April 2021, 6:34 pm EST
    Posted 7 April 2021, 6:34 pm EST
    Hello.
    I would like to add an extra row to the columnHeaders to display some static meta information (artificially create extra headers).
    I tried other examples listed on this forum and here is the closest I got:
    https://stackblitz.com/edit/js-fvmqz2?file=index.js
    The row is added, but it is blank. Notably, when traversing within grid.formatItem.addHandler, only the original rows #0 and #1 are present. Where is row #2 and how can I access it?
  • Posted 8 April 2021, 4:53 am EST
    We are able to replicate the issue at our end and hence we have forwarded it to the concerned team for further investigation of the issue(Internal tracking Id: WJM-19668).
    Till then you may work around the issue by using AllowMerging property to merge headers as demonstrated in the following sample:
    https://stackblitz.com/edit/js-srdeu2?file=index.js
    Sharad
  • Posted 9 April 2021, 9:21 am EST
    Hi Sharad -
    I tried your approach with merging - it worked on the contrived example (as shared above), but when I attempted to port it to my real app, I still faced similar issues (could be interaction with other formatItem handlers).
    Unfortunately I cannot share source code of the real app, so I’d like to wait until a fix is released for the nested columns approach (I will keep watching this thread).
  • Posted 12 April 2021, 2:11 am EST
    Thank you for the feedback. I’ll keep this thread updated with the updates.
    You could also try another approach of adding the row as a normal data row and setting the frozenRows to 1 to fix it at the top position to fix it at the top just like header rows. The following sample demonstrates the same:
    https://stackblitz.com/edit/js-sqcv9f?file=index.js
    Let me know if this works for you.
