Combobox in flexgrid issue
Posted by: petr.somek on 2 November 2020, 10:02 am EST
  • Posted 2 November 2020, 10:02 am EST - Updated 3 October 2022, 3:11 pm EST
    I have this example:
    one simple grid with two columns: name and group. Group’s values contains numbers 1 - 10. I’m using combobox component for editing group value.
    I have initialized the the with these data:
    {name:‘John’, group:2},{name:‘Jack’, group:1}
    When I edit group value on the 1st row, combobox appears with selected value 2. But when I try the same with 2nd row I expect that the ‘1’ value will be selected in opened combobox. But value ‘10’ is selected.
    Here is my code:
    import { FlexGrid } from '@grapecity/wijmo.grid';
    import * as wjcCore from '@grapecity/wijmo';
    import { ComboBox  } from '@grapecity/wijmo.input';
    class App {
    	constructor() {
    		this._initializeGrid();
    	_initializeGrid() {
    		// creates the grid
    		this._theGrid = new FlexGrid('#theGrid', {
    			autoGenerateColumns: false,
    			columns: [
    				{ binding: 'name', header: 'Name',  width: '*', minWidth: 200, isContentHtml:true , isReadOnly: true },
    				{ binding: 'group', header: 'Group', width: '*', minWidth: 200,
    					editor: new ComboBox(document.createElement('div'),
    						itemsSource : [1,2,3,4,5,6,7,8,9,10]
    		this._theGrid.itemsSource=new wjcCore.CollectionView([
    			{name:'John', group:2},{name:'Jack', group:1}
    		this._theGrid.rowHeaders.columns.defaultSize = 90;
    document.readyState === 'complete' ? init() : window.onload = init;
    function init() {
    	const app = new App();
    I’m attaching the image where can be seen described situation.
  • Posted 3 November 2020, 3:22 am EST
    Hi Petr,
    This seems like a bug. I have forwarded this to the developers for further investigation with internal tracking id 467919. I will update you as soon as I will hear from them.
  • Posted 18 November 2020, 4:57 am EST
    Hi Petr,
    The issue has been fixed in the latest nightly build of Wijmo. You can verify the same using the sample link below:
    https://stackblitz.com/edit/js-uggvdf
    Note that nightly builds have not been passed through the QA cycles and are not suitable for production environment.
