Posted 8 April 2019, 2:53 am EST
The combo box input does not show the correct value on startup
please look here
https://stackblitz.com/edit/angular-jogs2l?file=src%2Fapp%2Fapp.component.html
Posted by: Meirav.Eliad on 8 April 2019, 2:53 am EST
please look here
Posted 9 April 2019, 8:51 am EST
We are able to replicate the issue at our end so we have forwarded the issue to the concerned team for further investigation(Internal tracking Id #374532).
In the meantime, you can solve this issue by using itemFormatter property of Combo Box instead of ng-template. Please refer to the updated sample demonstrating the same:
https://stackblitz.com/edit/angular-dmznay
~Sharad
Posted 10 April 2019, 12:43 am EST
I can not use itemFormatter since I am wrapping the combobox control and I am getting a ng-template from outside of it, so i do not now the format.
to change it in the wrapper control it means changing it in the uses of it, this is a lot of work.
Posted 12 April 2019, 7:32 am EST
The issue is fixed in the latest nightly build(5.20183.567-nightly.d20190411.t2300). You may confirm the same from the following sample which uses the nightly build: https://stackblitz.com/edit/angular-kkqdrb?file=src/app/app.component.html
Posted 14 April 2019, 2:55 am EST
great! when will this be in an official release
Posted 15 April 2019, 12:18 am EST
I need the npm release
Posted 15 April 2019, 8:47 am EST
Next stable build is excepted to be released in a week but the fix will not be included in this release since the code is already frozen for this release. So you may except the fix to be included in the next stable release after this release.
Posted 16 April 2019, 2:54 am EST
thank, Do you have estimated time
Posted 22 April 2019, 10:08 am EST
It seems that your issue fix has been included in the latest release 5.20191.603. Please refer to the following demo sample for reference:
https://stackblitz.com/edit/angular-ao7bdh?file=src/app/app.component.html
Further, please refer to the latest release blog:
https://www.grapecity.com/en/blogs/wijmo-release-2019-v1
Manish Gupta
