Configure the Popup in Pivot Report
Posted by: sskss1ss2 on 27 July 2022, 12:35 am EST
    Posted 27 July 2022, 12:35 am EST - Updated 3 October 2022, 11:49 am EST
    I’ve Pivot report that has a column inserted after manipulating an existing column
    In the above image Average Score is an added column after halving the Journey column.
    My query is that, when we double click on this column we’ve a pop up coming up, rather than displaying the Header name i.e Average Score in the column, it displays the technical Name. Added screenshot for reference
    Is there any way to handle this?
  • Posted 29 July 2022, 3:38 am EST
    The observed behavior is by design. The detail dialog of the PivotGrid display’s the field name instead of the header as the Detail grid in the detail dialog is a Flexgrid instance and it generates columns automatically based on the data source for Pivot Grid. Similarly, the field setting’s dialog display’s the field name based on the data source.
    The reason for the above behavior is that if we show headers instead of binding, it brings ambiguity as the same binding can be used in PivotGrid with different headers in the DetailDialog grid.
    For example, in https://www.grapecity.com/wijmo/demos/OLAP/PivotGrid/DetailDialog/purejs ‘sales’ binding is used with two different headers ‘Sales’ and ‘Diff’. The detailDialog and setting dialog shows row data which has only one column with ‘sales’ binding, so here It would be unclear which header should be used in this case.
    Therefore, to implement the above requirement, you need to manually update the column header in the displayed grid in the detail dialog, and to update the field setting dialog header you may add a context menu event on PivotGrid and use the underlying instance of the listbox to update the setting dialog header. Please refer to the sample given below for the same:
    https://stackblitz.com/edit/js-bl25yn?file=index.js
    Feel free to revert back if you have any further queries/ concerns.
    Dushyant Sharma
  • Posted 11 August 2022, 8:35 am EST
    Yes this worked. Thanks
