Context Menu
Posted by: hoang-nguyen on 14 September 2017, 12:12 pm EST
    Posted 14 September 2017, 12:12 pm EST
    I am trying to add a context menu to my flexgrid on an ionic app.
    This is my html:
    <ion-content padding>
    <wj-flex-grid
    #flex [itemsSource]=“dataCollection”
    [autoGenerateColumns]=“true”
    [headersVisibility]=“1”
    [isReadOnly]=“true”
    wj-context-menu=“#idMenu”>
    </wj-flex-grid>
    <wj-menu id=“idMenu” ng-show=“false”>
    <wj-menu-item cmd=“cmdMenu1” cmd-param=“1”>Menu 1</wj-menu-item>
    <wj-menu-item cmd=“cmdMenu2” cmd-param=“2”>Menu2</wj-menu-item>
    </wj-menu>
    </ion-content>
    I do not know what I am missing
    When I ran it, right click of the mouse did not popup any context menu at all. What am I missing here? Thank you very much.
  • Posted 14 September 2017, 12:12 pm EST
    Here is my sample code
    Hello Hoang,
    The problem in your code is with reference passed between FlexGrid and Menu. Please refer to the attached sample that implements the same.
    Manish Kumar Gupta
    2017/08/FlexGrid_contextmenu_select_row.zip
    Thank you sir. It works like a charm.
    Just one more question. If I need to show context menu only when user right click on column header, is there a way to achieve it? Thank you sir very much.
    Hello Hoang,
    For this, you need to prevent contextmenu for cell type other than columnHeader. Please use the following code snippet for the same:
    this.flex.hostElement.addEventListener('contextmenu', (e) => {
                let ht = this.flex.hitTest(e);
                if(ht.cellType!==wjGrid.CellType.ColumnHeader){
                    e.preventDefault();
                    e.stopImmediatePropagation();
            },true);
    Hope it helps!
    Manish Kumar Gupta
    Thank you Manish for quick replying. I have copied and tried your code. It is working like a charm. However, When I tried to change it to ionic’s style by seperating ts and html: This is what I did:
    TS:
    contextMenu(event) {
    let ht = this.flex.hitTest(event);
    if (ht.cellType !== wjGrid.CellType.ColumnHeader) {
      event.preventDefault();
      event.stopImmediatePropagation();
    HTML:
    <wj-flex-grid
    [isReadOnly]=“true”
    (contextmenu)=“contextMenu($event)”
    [wjContextMenu]=“ctxMenu”>
    </wj-flex-grid>
    <wj-menu
    #ctxMenu
    style=“display:none;”
    [header] = “‘Main Menu Test’”
    (itemClicked)=“menuItemClicked(ctxMenu, $event)”>
    &lt;wj-menu-item [value]="'AutoSizeColum'"&gt;Auto Size Column&lt;/wj-menu-item&gt;
    &lt;wj-menu-item [value]="'AutoSizeRow'"&gt;Auto Size Row&lt;/wj-menu-item&gt;
    &lt;wj-menu-separator&gt;&lt;/wj-menu-separator&gt;
    &lt;wj-menu-item [value]="'ExportExcel'"&gt;Export Excel&lt;/wj-menu-item&gt;
    &lt;wj-menu-item [value]="'ExportPDF'"&gt;Export PDF&lt;/wj-menu-item&gt;
    &lt;wj-menu-item [value]="'Print'"&gt;Print&lt;/wj-menu-item&gt;
    &lt;wj-menu-item [value]="'Grouping'"&gt;Grouping&lt;/wj-menu-item&gt;
    &lt;wj-menu-item [value]="'People'"&gt;People&lt;/wj-menu-item&gt;
    &lt;wj-menu-item [value]="'Productivity'"&gt;Productivity&lt;/wj-menu-item&gt;
    &lt;wj-menu-item [value]="'FreezePanes'"&gt;Freeze Panes&lt;/wj-menu-item&gt;
    </wj-menu>
    </ion-content>
    It executed through contextMenu(e) function but did not prevent it from popping up on column header only. I checked futher and added
    event.returnValue = true;
    to it. It worked parttilally because the contecxt’s menu still show but under the browser’s menu. I guessed I miss another parameter to set. What I am missing here sir?
    https://www.dropbox.com/s/wyn1426z2ri4ht8/wijmoTest.7z?dl=0
    Hello Hoang,
    The reason for this is to capturing event. The code snippet provided in the previous reply is used capturing of event since the contextmenu is already captured by wjContextMenu property.
    Hence, you need to use the above provided solution.
    Manish Kumar Gupta
    Thank you sir very much for clarification.
  • Posted 24 August 2021, 7:50 am EST
    Hi Team I am using Context-menu in Wijmo TreeView is there any way we can make WJ-menu-item as disable.
    Thank You
  • Posted 25 August 2021, 8:19 am EST
    I have replied to your query on the post below:
    https://www.grapecity.com/forums/wijmo/-disabling-the-wj-menu-ite
