Posted 10 October 2019, 4:42 am EST
Hello, I have to customize pdf viewer, how I can do this in angular 8? including icons, fonts and etc
Posted by: apoddubnjak4 on 10 October 2019, 4:42 am EST
Posted 10 October 2019, 5:35 am EST
also I want to draw in pdf
how I can do this?
Posted 10 October 2019, 6:59 am EST
How I can change controls in menu?
Posted 11 October 2019, 2:31 am EST
Hi Andrew,
Regarding icons:
You may customize the icons using CSS rules, mainly fill and stroke:
.wj-viewer .wj-btn-group .wj-btn svg.wj-svg-btn {
fill: orange;
stroke: blue;
Regarding fonts:
To change the font of the PDF viewer, you may simply set the font-family CSS rule to the required font:
.wj-viewer {
font-family: sans-serif;
Regarding drawing in PDF:
Could you please confirm whether you wish to draw on the PDF document? If this is your requirement, then we are sorry but this is not possible. But if you have any other requirement, could you please explain it a little more?
Regarding changing controls:
Could you please explain more about what controls you wish to change?
Posted 16 October 2019, 9:06 am EST - Updated 3 October 2022, 2:47 pm EST
Thanks, I have done this
possibility to draw I will implement later
now I have second issue
PDF file does has been downloaded ( I see it in “network” tab in inspector). but then I have in console error:
zone.js:202 Uncaught SyntaxError: Unexpected token % in JSON at position 0
at JSON.parse ()
at _parseExecutionInfo (es5-esm.js:14)
at Object.onFulfilled (es5-esm.js:14)
at e.onFulfilled (es5-esm.js:14)
at es5-esm.js:14
at ZoneDelegate.invokeTask (zone.js:431)
at Zone.runTask (zone.js:198)
at ZoneTask.invokeTask (zone.js:513)
at ZoneTask.invoke (zone.js:502)
at timer (zone.js:3041)
When I open in separate tab link of my PDF, hosted in server - pdf is downloaded and everything fine
thanks
Posted 17 October 2019, 12:12 am EST
Could you please let us know on which server you have hosted the PDF document? The wijmo PDFViewer only supports hosting of PDF document using the C1WebApi PDF Services. For more information on C1WebApi PDF service, please refer to the link below:
https://help.grapecity.com/componentone/NetHelp/c1webapi/webframe.html#PDFDocumentServices.html
But, if you are already using C1WebApi for hosting the document, could you please provide us with a sample replicating the issue along with the PDF service url?
Posted 17 October 2019, 2:28 pm EST
Now no issues with server
How I can customize search in pdf?
Posted 18 October 2019, 2:27 am EST
Could you please explain more about what you wish to customize in the search so that I could investigate further?
Posted 18 October 2019, 7:49 am EST
I want to change styling, search button, search pannel, text, icons(change your svg icon), and etc
I want to do it in HTML, not in js
Do you have in your viewer api function, which make search?
I pass to this function string, I want to be found
and it return array of objects, where needed string was found?
Posted 21 October 2019, 7:59 am EST
Regarding search customization:
Since most of the icons in the PDFViewer control are made using SVG elements, I would not recommend you to change the icons of the viewer. But, you can change the style of the icons by using the CSS rules that I provided earlier.
Regarding the search function:
We are sorry but since search is performed internally by the viewer, therefore no API is available publicly.
Posted 24 October 2019, 4:51 am EST
got it, thanks
can you tell me how I can get book page width and height?
I have to insert custom elements in pages, element position depends on height of page and width.
but when I try to get height and width of page or svg via JS, I alway get height:0 and width:0
the second solution(I am not sure): to get page width and height after first page content was downloaded, but I dont see in your documentation event which emitted when book or page is loaded
how you can help me to solve a problem of dinamically adding elements into pages depending of book page width and height?
Posted 25 October 2019, 4:28 am EST
The Pdf rendered in the PDFViewer using SVG elements with a wrapper DIV which has class .wj-view-page.
You may get the page using following code-snippet:```
document.querySelector(“.wj-view-page”)
But this only returns for the current page if the page view is single page view.
PS: This DOM gets changed whenever the scrolling or any other action performed on the Viewer.
It would be great if you may share your requirement with us so that we may provide solutions accordingly or discuss with the concerned team if required.
Manish Gupta
Posted 25 October 2019, 5:04 am EST
try to do it in ngOnInit() or ngAfterViewInit()
and try to get height or width
you will always get zeros
my requirements: I have created component and it have to be positioned in page corners
I tried to insert, but I have to know correct width and height of page
also different books have different page width and height
also bad UX - when I change page - it start downloading - if downloading is long, I start scrolling and as user, can forgot that I change page - and when page is downloaded - it auto scroll to that page
and worse is that if I change few pages at small time - they are downloading long - and when downloaded I, as user, cant understant why my scroll “jump” from page to page
where we can chat in “direct” so it will be faster?
Posted 28 October 2019, 3:48 am EST
The document should be loaded properly in order to get the dimensions of the SVG element. I have created an enhancement request to add an event for the document load with the internal tracking id 403328.
Regarding scrolling:
Could you please try setting the viewMode of the PDFViewer to Continuous and let me know if this solves your issue.
If the issue is not resolved then let us know and we will create a case on our support portal and we will contact you.
