Posted 1 August 2023, 7:59 am EST
I’ve a flexchart whose X-Axis can be a alpha numeric value. How do i write a custom sort for this?
Posted by: sskss1ss2 on 1 August 2023, 7:59 am EST
Posted 2 August 2023, 2:26 am EST
You can sort alphanumeric values using the sortComparer method of collectionView with the third-party library ‘alphanum-compare’s’ compare function. This will sort all the values alphanumerically. Please refer to the sample link below demonstrating the same:
https://stackblitz.com/edit/angular-f248k7?file=src%2Fapp%2Fapp.component.ts
Sonu Kumar Pandey
Posted 2 August 2023, 4:46 am EST - Updated 2 August 2023, 4:54 am EST
Thank you for the revert.
Is it not possible to trigger the sortComparer method from flexChart’s CollectionView Object?
Because when i try to do it this way
this.chart.collectionView[ ‘sortComparer’ ] = (val1, val2) => {}
it gives me the below error
TypeError: ‘caller’, ‘callee’, and ‘arguments’ properties may not be accessed on strict mode functions or the arguments objects for calls to them
at Function.r (:1:83)
Posted 2 August 2023, 8:15 am EST
The sortComparer is not a function but a property of CollectionView which takes a callback function to define the sorting behavior of data.
To perform the sorting, or call the sortComparer function you need to add the desired binding into the sortDescriptions array(as done in the above-shared sample link for month binding).
