CustomGrid extending from wjFlexGrid does not work under Ivy (Angular 9)
Posted by: benjamin.schaeublin on 10 March 2020, 10:02 am EST
    Posted 10 March 2020, 10:02 am EST
    We have created a Grid which is extending from wjFlexGrid, following a sample which is somewhere out there in a sample.
    Here a shortened sample, for what i mean
    import {
    	ChangeDetectorRef,
    	Component,
    	ElementRef,
    	forwardRef,
    	Inject,
    	Injector, Optional,
    	SkipSelf,
    	ViewChild
    } from '@angular/core';
    import {WjFlexGrid, wjFlexGridMeta} from '@grapecity/wijmo.angular2.grid';
    import {CollectionView, DataType, escapeHtml, Rect, SortDescription, Tooltip} from '@grapecity/wijmo';
    import {CellRange, CellRangeEventArgs, CellType, Column, DataMap} from '@grapecity/wijmo.grid';
    @Component ({
    	selector: 'app-custom-grid',
    	templateUrl: './customGrid.component.html',
    	inputs: [ ... wjFlexGridMeta.inputs, 'name'],
    	outputs: [...wjFlexGridMeta.outputs, 'onFilterApplied'],
    	providers: [
    		{ provide: 'WjComponent', useExisting: forwardRef(() => CustomGridComponent) },
    		...wjFlexGridMeta.providers
    export class CustomGridComponent extends WjFlexGrid {
    	/* example custom input property */
    	public name: string;
        /* 9 other custom input properties */
    	constructor(@Inject(ElementRef) elRef: ElementRef,
    				@Inject(Injector) injector: Injector,
    				@Inject('WjComponent') @SkipSelf() @Optional() parentCmp: any,
    				@Inject(ChangeDetectorRef) cdRef: ChangeDetectorRef) {
    		super(elRef, injector, parentCmp, cdRef);
    	/*  is called in the last line of any Wijmo component's constructor, and perform necessary initializations here. */
    	public created() {
            // some custom init stuff here
    if i build it with ivy, i get following error:
    Compiling TypeScript sources through ngc
    ERROR: src/lib/wijmo/components/customGrid/customGrid.component.ts:24:10 - error NG1010: Failed to resolve inputs at position 0 to a string
    24  inputs: [ ...wjFlexGridMeta.inputs, 'name'],
    If i disable ivy, the build seems to be okay, but another module that uses the custom grid has this error:
    ERROR in Can't bind to 'itemsSource' since it isn't a known property of 'app-custom-grid'.
  • Posted 11 March 2020, 5:31 am EST
    There are some changes that you need to do in order to inherit the FlexGrid while using the Ivy compiler. Please refer to the sample attached. I have added comments in the CustomGridComponent.ts file for your reference.
    flexgrid extend.zip
  • Posted 11 March 2020, 11:43 am EST
    Hi Ashwin
    Thank you for your sample, that worked perfectly.
