Posted 15 July 2019, 5:17 am EST
You may handle the click event on the dropdown elements of both InputDate and InputTime and set a flag in the event handler that indicates that the value has been changed using the UI. Please refer to the code snippet below:
In TS:
isDropSelected: boolean
valChanged(dt: wjcInput.InputDateTime, e: wjcCore.EventArgs) {
console.dir('value changed');
if (this.isDropSelected) {
console.dir('value changed using dropdown');
this.isDropSelected = false;
initDT(dt: wjcInput.InputDateTime) {
var self = this;
dt.calendar.hostElement.addEventListener('click', e => {
self.isDropSelected = true;
}, true);
dt.inputTime.dropDown.addEventListener('click', e => {
}, true);
In HTML:
<wj-input-date-time (initialized)="initDT(dt)" (valueChanged)="valChanged(dt, $event)" #dt>
</wj-input-date-time>
You may also refer to the sample below:
https://stackblitz.com/edit/ckkyne-dr3cjd
