Definition of missing values in pivot engine/pivot grid
Posted by: georgekam96 on 26 September 2019, 5:13 am EST
    Posted 26 September 2019, 5:13 am EST
    Hello!
    I would like to know what is the definition of missing values in the pivot engine and pivot grid classes. It seems that 0 (zero) is interpreted as a missing value which does not make sense in a lot of cases.
    Is there a way to change which exact values will be labeled as ‘missing values’?
  • Posted 27 September 2019, 12:22 am EST
    Hi George,
    Missing values in PivotEngine are just what it says, the values which are missing from the data source.
    Also, 0 should not be considered as a missing value. So, we have forwarded a bug report to the dev team with internal tracking id 399859. We will update you as soon as we hear from them.
  • Posted 14 October 2019, 4:44 am EST
    Hi George,
    The issue has been fixed in the nightly build of wijmo. You may verify the same using the sample below:
    https://stackblitz.com/edit/js-hmackz
    PS: Nightly builds have not passed through the QA cycles as all of our release builds do. Therefore, they are not suitable for production.
