Deleting the default header
Posted by: nivishapanwar on 29 December 2020, 9:29 am EST
  • Posted 29 December 2020, 9:29 am EST
    I want to remove the default header from my wijmo grid and display only the grid data .
    How can I remove those default headers?
    I have attached the screenshot of my screen.
    Nivisha
  • Posted 29 December 2020, 11:44 pm EST
    Hi Nivisha,
    You can use the headersVisibility property of the FlexGrid to show/hide the default headers:
    https://www.grapecity.com/wijmo/api/classes/wijmo_grid.flexgrid.html#headersvisibility
  • Posted 30 December 2020, 2:59 am EST
    Hi Ashwin,
    If I use header visibility then , the whole radio box column is also getting disappeared.
    <wj-flex-grid class=“bento-flex-grid” [itemsSource]=“data” [autoClipboard]=“false” [showSort]=“true”
    [stickyHeaders]=“true” [headersVisibility]=“false”>
    <ng-template wjFlexGridCellTemplate [cellType]=“‘RowHeader’” let-cell=“cell”>
    <wj-flex-grid-column [binding]=“‘WorkflowTemplateName’” [width]=“1250” [header]= " ’ ’ ">
    I have attached both screenshots.
    Nivisha
  • Posted 31 December 2020, 7:20 am EST
    Hi Nivisha,
    From the code snippet, we could observe that you are using row header area to display checkboxes. So to hide the columnheader while displaying the row headers you need to set the headersVisibility property to “Row”. Please refer to the following code snippet:
    <wj-flex-grid class="bento-flex-grid" [itemsSource]="data" [autoClipboard]="false" [showSort]="true"
    [stickyHeaders]="true" [headersVisibility]="'Row'">
