Disable default context menu for wj-pivot-grid
Posted by: bhati.bhati on 26 August 2019, 8:27 am EST
    Posted 26 August 2019, 8:27 am EST
    How can I disable default context menu for wj-pivot-grid. I want to make it invisible.
    Deepak
  • Posted 27 August 2019, 1:18 am EST
    Hi Deepak,
    If you wish to show the default browser context menu then you may set the customContextMenu property of PivotGrid to false.
    <wj-pivot-grid [customContextMenu]="false" ...></wj-pivot-grid>
    But, if you wish to hide the default browser menu also, then in addition to setting the customContextMenu to false, you will also need to handle the contextmenu event listener to the host element of the PivotGrid and call the preventDefault method:
    pivotGrid.hostElement.addEventListener('contextmenu', e => {
    	e.preventDefault();
    }, true)
  • Posted 27 August 2019, 3:08 am EST
    Thanks Ashwin,
    It works like a charm.
    Deepak
  • Posted 26 March 2024, 2:21 am EST
    Is it possible to customize the right-click menu on the default browser to add options for controlling subtotal display per dimension?
  • Posted 28 March 2024, 8:29 am EST
    Hi Hussein,
    We have already answered this query on our other portal, here’s a copy of the response -
    You can set the ‘customContextMenu’ property of the PivotGrid to false, to hide the default context menu of the grid and handle the ‘contextmenu’ event on the PivotGrid’s host element to show a custom context menu as per your requirements, you can use Wijmo’s Menu control as a custom context menu.
    Please refer to the following sample demonstrating the same - https://stackblitz.com/edit/react-9n92j7?file=index.js
    In the above sample, we have added the ‘RemoveField’ and ‘ToggleSubtotals’ options in the context menu, you can modify the menu options as per your requirements.
