Disable sort on CollectionView
Posted by: loicgeo on 14 September 2017, 11:22 am EST
    Posted 14 September 2017, 11:22 am EST
    Hello
    i’m using a FlexGrid and i would disable sorting on initial data source.
    Is it possible ?
    Thank you for all
    bye :wink:
  • Posted 14 September 2017, 11:22 am EST
    Hello Loicgeo,
    I am not clear with your requirement. If you want to disable sorting on FlexGrid then you can set its allowSorting property to false or cancel the sorting in sortingColumn event.
    At collectionView level, you can clear the sortDescriptions collection to remove the sorting. If it does not help then kindly elaborate on your requirement so that I can suggest you accordingly.
    Thank you for your reply, was useful for me ;o)
    Hi Ashish,
    I just want to disable column sorting on a particular column, is that possible? I tried allowSorting= false, however it disables the sorting for entire FlexGrid.
    Any code example?
    Hi Nitin,
    My apologies for the late reply. I hope that this reply is still useful to you.
    Please try the following code to disable sort on a particular column
     $scope.sortingColumn = function(sender, args) {
        // determine new sort
        if (sender.columns[args.col].binding=="age") {
                args.cancel = true;
    <wj-flex-grid items-source="data" selection-mode="Row" sorting-column="sortingColumn(s,e)" item-formatter="itemFormatter">
        <wj-flex-grid-column header="Name" binding="name"></wj-flex-grid-column>
        <wj-flex-grid-column header="Age" binding="age"></wj-flex-grid-column>
      </wj-flex-grid>
    Abhishek
    actually i want to hide sorting options(ascending descending) for one column.How can that be possible?Or if it is possible to hide whole filter
    any update on this?
    Hi Dharna,
    You can remove from particular column by setting FilterType to None for specified column.
    You can also hide sort button for specific column by hiding in filterChanging event.
    For your reference, please see the attached sample that implements the same.
    Manish Kumar Gupta
    2017/05/FlexGrid_filter_sortButton.zip
  • Posted 5 February 2020, 12:26 pm EST
    Hi ,
    I want to disable sorting in wijmo flex grid but in column level.
    I used allow-sorting=“false” . but it didnt work.
    below is my column of wijmo .where I donot want to sort the colum.
    binding=“irsmstatusName”
    header=“IRSM Status”
    [dataMap]=“statusMap”
    [width]=“210”
    <ng-template wjFlexGridCellTemplate cellType="ColumnHeader" let-cell="cell" let-item="item">
      <div>
        <div>
          <label class="">IRSM Status</label>
        </div>
        <div>
         <wj-combo-box
          [itemsSource]="status"
          [(selectedItem)]="cell.value"
          [isEditable]="false"
         </wj-combo-box>
          <button
            [wjTooltip]="'copy below'"
            style="align-items: center;padding: 0px !important"
            class="btn btn-light"
            (click)="onCopyBelowClick('irsmstatusName', cell.value)"
            <span>
              <fa-icon icon="level-down-alt"></fa-icon>
            </span>
          </button>
        </div>
      </div>
    </ng-template>
    Vishakha
  • Posted 6 February 2020, 4:57 am EST
    Hi Vishakha,
    The allow-sorting property is used in AngularJS. In Angular, to disable sorting in a column, set its allowSorting property to false as follows:
    <wj-flex-grid-column [allowSorting]="false" header="Amount" binding="amount"></wj-flex-grid-column>
    https://stackblitz.com/edit/angular-kvasq5
