Disable spesific items on WjComboBox
Posted by: davidzal1992 on 8 March 2021, 8:39 am EST
    Posted 8 March 2021, 8:39 am EST
    Hey, there is an option that i can disable some items from my drop down list?
    for example if I have 3 items - “yellow”,“orange”,“red” i want to disable the orange one for some reason and this option will be disabled for all users but they still will see her on a list.
  • Posted 9 March 2021, 1:33 am EST
    Hi David,
    You can handle the formatItem event of ComboBox and add the wj-state-disabled CSS on items which are disabled:
    https://stackblitz.com/edit/js-g5dbye
  • Posted 9 March 2021, 4:02 am EST
    This option is supported in Angular as well? there is example that I can find?
  • Posted 9 March 2021, 11:57 pm EST
    Yes, It will work in angular also.
    In HTML:
    <wj-combo-box #cb (formatItem)="onFormatItem(cb, $event)" ...></wj-combo-box>
    In TS:
    onFormatItem(s, e) {
    	let item = e.data;
      	// add this CSS class
      	wjcCore.toggleClass(e.item, "wj-state-disabled", isDisabled(item));
  • Posted 11 March 2021, 8:22 am EST
    Thakns for that, amazing! working well!
    1 more question, I have toolTip directive, there is some way that I can add my attribute directive to items?
    For example I use [toolTip]=“hover me”, when user hover over selected items, there is option to add my attribute directives ?
  • Posted 12 March 2021, 1:09 am EST
    I am glad that the solution helped you. If you need to add angular components or directives, then you will need to use the wjItemTemplate directive. Using this, you can customize the items displayed in the ComboBox, like, adding a tooltip directive:
    https://stackblitz.com/edit/angular-9-0-0-rc-1-wqcelc
    In this sample, open the drop-down menu and hover over the items. Note that this will only work for non-disabled items because disabled items have their pointer-events set to none. So, the events like mouseover, which helps in displaying the tooltips, will not work.
