Drag and drop functionality in wijmo listbox
Posted by: nivishapanwar on 22 February 2021, 2:12 am EST
    Posted 22 February 2021, 2:12 am EST
    According to my project requirement, the records in listbox should be dragged and dropped anywhere in the listbox .For every record in the listbox a black dot is present , so that when we click on that that specific record can be dragged and dropped in other place in listbox.
    Is that possible in wijmo listbox?
    Nivisha
  • Posted 23 February 2021, 8:20 am EST
    Hi Nivisha,
    I’ve prepared a utility function for you to enable drag-drop in listbox. Please refer to the following sample which demonstrates the same:
    https://codesandbox.io/s/wijmo-angular-forked-dyrh3?file=/src/app/app.component.ts
    You may simply copy-paste the listDrag.ts file in your application.
  • Posted 23 February 2021, 11:12 am EST
    Hello Sharad,
    Thank you for the help. It worked for me.
    Can we use bento drag and drop icon inside the wijmo listbox?
    Nivisha
  • Posted 24 February 2021, 9:27 am EST
    Hi Nivisha,
    you may use formatItem event to add icons inside the list. Please refer to the following demo which demonstrates the same:
    https://www.grapecity.com/wijmo/demos/Input/ListBox/Customization/purejs
    I couldn’t find any public bento packages, If you need to prepare a sample using bento-icons then please share some resources/document URL where I could get and refer to use the bento icons?
  • Posted 24 February 2021, 10:09 am EST
    Hello Sharad,
    Yeah I have checked formatitem yesterday, but it dont have the drag and drop icon.
    The bento icon which have to be used is bento-icon-drag-drop.
    https://ng.bento.ui.int.thomsonreuters.com/components/icons
    I have attached the sample screen.
    Remove
    For every record that drag and drop symbol have to be added.
    Thank you .
    Nivisha Panwar
  • Posted 25 February 2021, 2:38 am EST - Updated 3 October 2022, 1:55 pm EST
    I’m unable to open the shared URL. Please make sure it is a public URL.
    It shows “This site can’t be reached” error.
    Or if your resources are private and you can’t share them here then you may create a ticket on our private support portal and share the resources there.
    https://www.grapecity.com/my-account/my-support
