Drop-down lists problem into flex grid cell
Posted by: m.omar on 4 December 2019, 7:39 am EST
    Posted 4 December 2019, 7:39 am EST
    I am using wijmo flex grid in “purejs” mode.
    After update to latest version (5.20193.637) some of cells witch contains drop-down lists gives the following error :
    ERROR : Uncaught ** Assertion failed in Wijmo: Found duplicate key: 1 Error
    Latest Version (5.20193.637) gives error
    http://jsfiddle.net/0pjf1tc6/20/
    Old Version (5.20182.523) working fine
    http://jsfiddle.net/0pjf1tc6/21/
    Note : according to my investigation this happens because ddl data-source contains duplicate “ID”. My product business allowed duplication in ID with different grid rows. in other words my product business uniqueness is per row .
  • Posted 5 December 2019, 12:58 am EST
    Hi Omar,
    We were able to replicate the issue at our end so we have forwarded a bug report to the dev team with internal tracking id 409355. We will update you as soon as we will hear from them.
  • Posted 5 December 2019, 1:50 am EST
    Its urgent case , currently I rollback to the old version.
    Waiting you fix ASAP.
  • Posted 5 December 2019, 2:16 am EST
    Hi Omar,
    I have told the dev team that this issue needs to be fixed as soon as possible.
  • Posted 10 December 2019, 1:45 am EST
    Any updates !!
  • Posted 10 December 2019, 3:02 am EST
    Hi Omar,
    The issue is fixed in the latest nightly build of wijmo. You may verify the same using the sample below:
    https://stackblitz.com/edit/js-qrdv9m
    Note that nightly builds are suitable for the production environment.
  • Posted 10 December 2019, 5:29 am EST
    Could you please provide me with link that i can download that nightly build.
    also i want to know what is the expected date for next official build.
  • Posted 11 December 2019, 1:04 am EST
    Hi Omar,
    If you are using NPM to install wijmo, then you can easily install the ‘nightly’ version and use it in your application.
    Also, we are sorry but we currently do not have an ETA on the next release build. I’ve asked the dev team and I will update you as soon as I will hear from them.
  • Posted 11 December 2019, 1:56 am EST
  • Posted 23 December 2019, 10:20 am EST
    Please check the example with Latest Version (5.20193.646-nightly.d20191221.t020634) not working !!!
    http://jsfiddle.net/oa4r9mLh/1/
    It gives the following errors :
    Uncaught ReferenceError: exports is not defined
    at wijmo.js:26
    Uncaught ReferenceError: wijmo is not defined
  • Posted 24 December 2019, 3:09 am EST
    Hi Omar,
    The builds downloaded from the npm package cannot be used directly as CDN. You will need to import them using a module loader like SystemJS.
    I have provided a sample that verifies the fix and also the redistributable package of wijmo of the nightly build that you can use to test at your end.
    Whenever the next hotfix will release, you can update your project to use the CDN link of the hotfix.
    Sample link: https://drive.google.com/file/d/1to-UzwMUXwqYnmIvDSP_5E0qygyALaqT/view?usp=sharing
  • Posted 24 December 2019, 5:13 am EST
