Drop-down on particular cell
Posted by: unnati.kbalas on 24 December 2019, 9:24 am EST
    Posted 24 December 2019, 9:24 am EST
    I tried 2 way to do this. first one is ```
    grid.formatItem.addHandler((s, e: wjcGrid.FormatItemEventArgs) => {
    if (e.panel.rows[e.row]._data[alt].controlType === ‘DropDown’){
    const theComboBox = new input.ComboBox(e.cell, {
    itemsSource: items
    but it loosing a control while grid update and second one is
    const col = s.columns[e.col];
    col.dataMap = [‘Washington’, ‘Miami’];
    this generates continues update on grid and it's for column. can anyone suggest me how could I put dropdown on single cell, not on entire column.
  • Posted 26 December 2019, 2:19 am EST
    Hi Unnati,
    You can set the DataMap for the entire column and remove the drop-down from those cells which do not require the data map. Please refer to the sample below:
    https://stackblitz.com/edit/angular-j2uamq
    This procedure will still use DataMap internally for non data map cells.
    You can also add the ComboBox directly to the cells using the formatItem event. Please refer to the sample link for a demo:
    https://stackblitz.com/edit/angular-cx9vfk
  • Posted 26 December 2019, 7:55 am EST
    Your solution is good but when I changed the dropdown value, Gridchanged or cellEditEnding event not called.
  • Posted 27 December 2019, 12:06 am EST
    Hi Unnati,
    If you will use the DataMap’s solution, the cellEditEnding and cellEditEnded event will fire as expected. You may verify the same using the updated sample below:
    https://stackblitz.com/edit/angular-s5njb3
    But while using the ComboBox as editors, you will need to raise these events manually. Please refer to the sample below for reference:
    https://stackblitz.com/edit/angular-6bs5dq
    Regarding gridChanged event:
    The gridChanged is an event for Row and Column class and only fires when the grid property of the row or column changes. Could you please explain your use case for this?
