Posted 23 April 2024, 1:02 pm EST
Hello Devansh,
Please refer to the following documentation for exporting the FlexGrid content as the CSV format.
https://developer.mescius.com/wijmo/docs/Topics/Grid/ImportExport/Export-To-Excel-CSV
As you would like to change the Date Format of the column before exporting.
For this, there are two ways:
- Change the Column date format before exporting as:
grid.columns[2].format = “yyyy-MM-dd”
And then export to the CSV. And after export, you may reset the format to the original format. But it might cause a flicker for the date column due to format change.
- Use a hidden FlexGrid with the same collectionView that would be used to visible FlexGrid. But this hidden FlexGrid would have the targeted column date format set from initial and on export this FlexGrid would be used.
Hope it helps!
Manish Gupta
