Extend Input-Mask validation method
Posted by: guido.corazza on 8 May 2019, 1:23 pm EST
    Posted 8 May 2019, 1:23 pm EST
    I´m currently extending the input-mask validation method with some regular expressions. Is there any way of extending the validation with some custom code? If so, should i add an event handler to the same event that wijmo uses internally?
    Thanks in advance.
    Guido
  • Posted 9 May 2019, 2:32 am EST
    Hi Guido,
    Yes, for this, you need to handle the keydown and keyup event for InputMask hostelement as following code snippet and do your custom validation.
    theMask.hostElement.addEventListener("keydown",function(e){
    // prevent default Settings
    e.preventDefault();
    // your code here
    },true);
    Manish Gupta
  • Posted 9 May 2019, 5:45 pm EST
    Hi Manish,
    Thanks for such a quick reply!
    What if i want Wijmo’s validation, and after that validation make some extra validation. Should i still need to handle the same events?
    Thanks in advance.
    Guido
  • Posted 10 May 2019, 5:43 am EST
    Hi Guido,
    You may check the add on validation using valueChanged event. Please refer to the following demo sample for reference:
    https://www.grapecity.com/wijmo/demos/Input/InputMask/Validation/purejs
    Further, if it is not suitable, you may use the keypress/keyup event same as following demo sample:
    https://jsfiddle.net/Wijmo5/j6er01bx/
    Hope it helps!
    If the issue persists or you have any further queries, please elaborate your use-case.
    Manish Gupta
  • Posted 30 May 2019, 9:44 am EST
    Thanks!
