FadeIn effect duration of popup / debounce
Posted by: sct999.1 on 26 July 2024, 2:38 pm EST
    Posted 26 July 2024, 2:38 pm EST
    Hello, I’d like to know what is the default duration of the fadeIn effect for the popup.
    Is that value configurable?
    Here is some context:
    The popup I have is hidden when the popup loses the blur, and it’s opened programmatically using a button.
    I want to debounce the open/close of the popup, specifically when user clicks on the open button while the popup is shown
    This is what happens
    1. Popup is open
    2. User clicks the open button again
      2.1 The mouse key is down, the popup loses the focus and thus it’s hidden
      2.2 The mouse key is released, and it triggers the opening of the popup
    Currently I’m implementing a flag named
    isAnimationInProgress
    which is bound to the
    showing
    shown
    hiding
    hidden
    events, however it seems those events are not synced with the animation end.
    So, I’m planning to use setTimeOut() to clear the
    flag (I know it might not be the best practice) but, for correct behavior, the value I use for setTimeOut should be the same as the animation time.
  • Posted 30 July 2024, 6:43 am EST
    We were not able to replicate the issue on our end, whereas upon investigation we found that the default time for fadein animation is 400ms.
    If you want to change animation time, then you can update the _ANIM_DEF_DURATION in the Control class, please refer to the following code snippet -
    import { Control } from '@mescius/wijmo';
    export class AppComponent {
      constructor() {
        Control._ANIM_DEF_DURATION = 600;
    If this information does not solve your problem; then please update this sample https://stackblitz.com/edit/angular-fhusf5?file=src%2Fapp%2Fapp.component.ts and help us in replicating the issue. We could help you better when we are able to replicate the issue on our end.
    Thanks, and Regards
