Flex-chart Stacked Bar Chart
Posted by: kun.leeing on 9 February 2020, 10:52 pm EST
    Posted 9 February 2020, 10:52 pm EST
    Hi guys,
    For the stacked bar chart example here.
    https://www.grapecity.com/wijmo/demos/Chart/Bar/StackedBar/purejs
    how to point the AxisX to Year and AxisY the amount number? I mean the other way around on X and Y to make the stacked bar erect.
    thanks.
  • Posted 9 February 2020, 11:23 pm EST
    Hi Kun,
    You just need to change the chartType to chart.ChartType.Column and the X-Axis and Y-Axis will be reversed:
    let barchart = new chart.FlexChart('#chart', {
    	header: 'Country GDP',
            chartType: chart.ChartType.Column,
  • Posted 10 February 2020, 2:14 am EST
    Thanks so much, Ashwin. That helped me resolve the issue. You are great!
    I have another question about the legend. Can I move it to another
    And for my example , I want to display an Array(336) and every item has more than 50 properties onto a stacked column chart. I put the code like below, but it does not work seemingly.
    <wj-flex-chart #flexChart class=“d-flex” [chartType]=“‘Column’” [bindingX]=“‘key’” [stacking]=“‘Stacked’”
    [palette]=“palette”>
    <wj-flex-chart-legend [position]=“‘Right’”>
    <wj-flex-chart-axis [wjProperty]=“‘axisY’” [title]=“‘Quantity (MW)’”>
  • Posted 11 February 2020, 12:06 am EST
    You can change the position of the legend to the bottom of the chart so that all the series can be displayed easily according to the available width. Refer to the demo link below. Try changing the Legend position and let us know whether this works for you.
    https://www.grapecity.com/wijmo/demos/Chart/Features/LegendsAndTitles/angular
  • Posted 14 February 2020, 5:09 am EST
    Hi Ashwin,
    Can I ask what else options in the series.symbolStyle ? I can see we can set
    fill: ‘green’,
    stroke: ‘yellow’,
    strokeWidth: 2
    What other options can we use? Did not find much info from our documentation.
    Kun
  • Posted 17 February 2020, 1:52 am EST
    Hi Kun,
    The symbolStyle property is used to apply CSS styles to the symbols of the Series. You can provide any CSS property that works with SVG elements as the options.
  • Posted 17 February 2020, 2:09 am EST
    Thanks so much for all your help, ashwin.
