Flex Grid Master- Detail Issues in Angular 7 cli project
Posted by: kapil.r.shah on 26 June 2019, 9:02 am EST
    Posted 26 June 2019, 9:02 am EST
    I am using Angular 7 . Installed Angular CLI and created a new app . Trying to make Wijmo Flex Grid work in Angular 7. Downloaded wijmo-5.20191.615 samples. Trying to make NestedGrids(RowDetail) work and getting errors.
    https://github.com/angular/quickstart/issues/263
    On more research , found that SystemJS configuration is not required. No need to edit anything in index.html.
    Able to load the data as per sample (app.component.html and app.component.ts) . However when I try to click the image to load the details, gives error
    Assertion Failed with Wijmo : CellRange expected
    Error Assertion Failed in Wijmo: Cell Range expected.
    Any solution to make the Flex Grid Master Detail work in Angular 7 project.
  • Posted 27 June 2019, 4:10 am EST
    Please refer to the sample attached that demonstrates how you can create a nested FlexGrid using angular-cli.
    If the issue persists for you please share a small sample replicating the issue so that we could further the issue.
    FlexGridDetail.zip
  • Posted 27 June 2019, 10:42 am EST
    I down loaded the project and did npm install to install the modules for wijmo. Got an error
    npm ERR! notarget No matching version found for electron-to-chromium@1.3.175
    npm ERR! notarget In most cases you or one of your dependencies are requesting
    npm ERR! notarget a package version that doesn’t exist.
    npm ERR! notarget
    npm ERR! notarget It was specified as a dependency of ‘flex-grid-detail’
    npm ERR! notarget
    I tried
    npm install wijmo
    npm install @grapecity/wijmo.all
    but still get the same error. Is their some way to install electron-to-chromium@1.3.175
  • Posted 28 June 2019, 3:14 am EST
    We think that you may have added electronjs as a dependency in your project. Could you please provide us with a small sample that replicates the issue so that we can investigate further?
  • Posted 1 July 2019, 3:00 pm EST
    I again did a npm install. I am able to load the master details component.
    Thanks for your help
