Posted 24 May 2019, 8:02 am EST
We have been using the line marker to draw an intersect on a line graph that will return the all the series data where they match the x value of where the line is drawn.
We have used HitTestInfo to query this information but have found that this selects the closest DataPoint rather than using the X value of wherever the line marker is drawn.
We’ve also tried to use the x,y coordindates to get this info, but we can only see a way of getting the x Value via the HitTest, which again uses closest DataPoint rather than current location.
Could you tell us if its possible to just return the x Value of wherever the LineMarker is? If you could also provide an example that would be super helpful.
Reece
