Flexchart Y-Axis labels
Posted by: phill_dutton on 11 December 2020, 6:19 am EST
  • Posted 11 December 2020, 6:19 am EST
    Hopefully this is a simple question to resolve.
    We are displaying 2 data series in a flexchart but we have noticed that the Y-Axis labels look a bit strange with a limited data set.
    In certain instances we have 2 items in our data set with a value of 0 and 1 for the series. i.e.:
    [{ date: ‘12/01/2020’, series1: 0, series2: 0 },
    { date: ‘12/09/2020’, series1: 1, series2: 0 }]
    What happens is the dates are shown accross the x-axis correctly, but the y-axis contains duplicate 0 and 1 values
  • Posted 16 December 2020, 6:07 am EST
    Hi Phil,
    I am not sure what exactly the cause could be since I am unable to replicate this at my end. I have attached a sample where this works correctly.
    You may also modify the sample to replicate the issue and send it back to us, so that we can investigate this further.
  • Posted 16 December 2020, 7:23 am EST
    Thanks for your reply. I figured out what the issue was, in our code we were using an itemFormatter on the y axis to show integer values.
    I tried removing this and the values displayed as decimals from 0 to 1 in 0.1 increments. The problem is we only want to see integer values on the Y axis, if I try setting the format property on the axisY to ‘N0’ this recreates the issue we are seeing with our itemFomatter.
  • Posted 18 December 2020, 5:01 am EST
    In this case you may set the step value using the majorUnit property of the axis. Please refer to the following code snippet and the sample demonstrating the same:
    chart.axisY.majorUnit = 1;
    https://codesandbox.io/s/wijmo-starter-forked-tv1nh?file=/src/index.js
