Flexgrid: Broken UI when loading grid data
Posted by: ramiro.olivencia on 19 May 2020, 4:20 pm EST
  • Posted 19 May 2020, 4:20 pm EST - Updated 3 October 2022, 4:17 pm EST
    Hi!
    We’ve updated our application to Angular 9 and version 2019.3 of Wijmo, which supports this angular version.
    Wijmo is running fine, but we observed that when the grids are loading now we observe that the grid takes some time to get correctly displayed and, in the meantime, it appears as if the design is broken.
    I’m attacking two captures as an example, before and after one grid finishes loading.
    Can you please give me a hint on where to start looking to avoid the grids appearing like this when the grids are loading? I clarify that the issue wasn’t present in the previous version of Wijmo that we used, 2019.1, which we used together with Angular 8.
  • Posted 20 May 2020, 7:52 am EST
    We are investigating your issue and will update you as soon as possible.
  • Posted 21 May 2020, 6:47 am EST
    We tried to mimic your sample as much as possible but we were not able to replicate the issue. Can you please modify the sample below so that it replicates the issue?
    https://stackblitz.com/edit/angular-sucepq
    Also, can you provide a video or GIF of how the grid loads? It will help us to understand better.
