Flexgrid - cell edit event value
Posted by: sravya_tamma on 29 April 2021, 5:09 pm EST
    Posted 29 April 2021, 5:09 pm EST
    I added a comment field using ng-template, When i type text in “comment” field, cellEditEnding event is being triggered. But when i log the value “newValue” i get empty.
    This event handler works fine for other fields and they don’t have ng-template
    Am i missing anything here ? please let me know
    s.cellEditEnding.addHandler((s: wjcGrid.FlexGrid, e: wjcGrid.CellEditEndingEventArgs) => {
                const oldVal = s.rows[e.row].dataItem[s.columns[e.col].binding];
                const newValue = wjcCore.changeType(s.activeEditor.value, wjcCore.DataType.Number, s.columns[e.col].format);
                s.rows[e.row].dataItem[s.columns[e.col].binding] = newValue;
                if (oldVal !== newValue) {
                    this.setChanged(s, e.row, e.col, oldVal);
    <wj-flex-grid-column header="Comments" [minWidth]="250" binding="comments" width="2*" word-wrap="true">
            <ng-template wjFlexGridCellTemplate [cellType]="'Cell'" let-cell="cell">
              <div class="divwordwrap" style="word-break:break-word;">
                {{cell.item.comments}}
              </div>
            </ng-template>
            <ng-template wjFlexGridCellTemplate [cellType]="'CellEdit'" let-cell="cell">
              <div class="tadiv">
                <textarea class="tadiv" [(ngModel)]="cell.value">   </textarea>
              </div>
            </ng-template>
          </wj-flex-grid-column>
  • Posted 4 May 2021, 2:04 am EST
    If you need to compare old and new values, then you may use the cellEditEnded event and get the old and new values using the following code:
    grid.cellEditEnded.addHandler((s: FlexGrid, e: CellEditEndingEventArgs) => {
    let oldValue = e.data;
    let newValue = s.getCellData(e.row, e.col);
      if (oldValue !== newValue) {
        console.log("value changed");
    You may also refer to the following sample demonstrating the same: https://codesandbox.io/s/adoring-tesla-wejyy?file=/src/app/app.component.ts
    ~sharad
