Posted 21 April 2018, 10:41 am EST
Problem:
DataMap documentation describes isEditable as “indicates whether users should be allowed to enter values that are not present on the DataMap”.
That does not appear to be the case when using a DataMap in an editable FlexGrid.
Reproduction steps:
See example fiddle http://jsfiddle.net/1tcjc3sq/15/ . The first column has isEditable = false, but uses the same field for data and display. It allows unlimited user entry. The second column uses different fields for data and display, and when the user focuses out of the editable cell, if the value entered is not a valid value, the cell is reverted to its last good entry.
Expected behavior:
If DataMap isEditable = false, DataGrid editable dropdown should behave the same way it works when the DataMap uses different label/data properties.
