FlexGrid Change Column height
Posted by: kun.leeing on 30 May 2019, 11:58 pm EST
    Posted 30 May 2019, 11:58 pm EST
    Hi experts,
    May I ask how can I change the Column’s height in wj-flex-grid?
    Have tried to put on css on column’s cell and add class to
    <wj-flex-grid-column *ngFor=“let col of dynamicColumns”
    [binding]=“col.binding”
    [header]=“col.header”
    [visible]=“col.visible”
    [width]=“col.width”
    class=“max-height”
    both did not work.
    Could someone give a clue on this?
  • Posted 3 June 2019, 5:44 am EST
    Hi Kun,
    As part of the design, you cannot set the height of a specific column. What we need to do is set the height for the rows.
    Please refer to the following code snippet:
    <wj-flex-grid #grid [itemsSource]="data" (initialized)="initGrid(grid)">
    </wj-flex-grid>
    /* equivalient initGrid menthod */
    initGrid(grid){
    	/* set height of all the rows */
    	grid.rows.defaultSize = 50;
    	/* set heighr of a specific row */
    	grid.rows[row_Index].height = 70;
    Further, to apply a class to a single column, we would recommend you use the cssClass property of the column instead of setting a class attribute in markup.
    Please refer to the link that demonstrates how you can use cssClass property:
    https://www.grapecity.com/wijmo/demos/Grid/Styling/Columns/purejs
    API Reference:
    • cssClass: https://www.grapecity.com/wijmo/api/classes/wijmo_grid.column.html#cssclass
    • defaultSize: https://www.grapecity.com/wijmo/api/classes/wijmo_grid.rowcollection.html#defaultsize
    • maxSize: https://www.grapecity.com/wijmo/api/classes/wijmo_grid.rowcollection.html#maxsize
  • Posted 5 June 2019, 11:51 pm EST
    Thanks so much, Sharad. :slight_smile:
