Posted 1 January 2024, 5:40 am EST - Updated 1 January 2024, 8:38 am EST
I just updated to Wijmo v20232 and the selection on my FlexGrids has stopped working.
I managed to narrow the problem down to this combination, which no longer works:
- column.visible=false
- item.property undefined
- CollectionView.getError function defined (returning null == no error)
Older version of Wijmo where the above combination works:
https://stackblitz.com/edit/ng11-wj20213-grid-colinvis-noval-geterror
(Still worked on 20221 or 20222, sorry I do not remember what version I had before)
Not working on latest version:
https://stackblitz.com/edit/wj20232-flexgrid-col-invisible-noval
I have defined the order and editing behavior of my columns in JS code and only a few of them are visible initially. Things like type or if an column is required is set when a column really gets used and is loaded from the database. So I would want to avoid having to specify dataType or isRequired on all my columns (which solves the problem).
Has something changed in your code running before CollectionView.getError ? Value coercion on dataType Object?
Edit: I just went through your ChangeLog.txt of 5.20232.939 and noticed this might be related to WJM-26326 fixed in 5.20231.900. Going back to build 5.20231.888 is unfortunately not an option as I have also already updated to Angular16.
