Posted 12 September 2019, 2:39 am EST
I am using dynamic table flex grid. When data in a column is all NULL, that column is not displayed on the grid. How do I display it regardless of null or not? thank you very much.
Posted by: molikbhatia on 12 September 2019, 2:39 am EST
Posted 13 September 2019, 12:50 am EST
Hi Molik,
We were able to replicate the issue at our end so we have forwarded a bug report to the dev team with internal tracking id 209741. We will update you on this as soon as we hear from them.
In the meantime, you may check whether the keys of an item in the data source matches the number of columns and if not then generate a new column manually. Please refer to the sample below:
https://stackblitz.com/edit/js-mtrl9a
Posted 13 September 2019, 3:00 am EST
Hi Ashwin,
Can you provide the above sample code in Angular 7 for wijmo flexgrid version: 5.20191.605
Posted 13 September 2019, 5:58 am EST
Please refer to the sample below that is implemented in the provided specifications:
https://stackblitz.com/edit/angular-qg9gw8
