FlexGrid Editor with PopUp Modal Editor
Posted by: ramirezcleandro on 18 September 2020, 11:14 am EST
  • Posted 18 September 2020, 11:14 am EST
    Good morning
    I have a problem with the popup editor, the user can edit the observation field both in the FlexGrid and also in the popup, when I open the popup, and modify the observation field, the field is updated correctly in the flexgrid, but when I do the same Operation in the second row, I change the value, and in the flexgrid it updates the 2 rows (row0 and row1), I don’t understand why it behaves that way, could you help me, here is the example
    https://jsfiddle.net/betbest/wd58h0a6/62/
  • Posted 21 September 2020, 12:55 am EST
    It seems like that issue does not occur in the latest version. Please refer to the updated sample link below:
    https://jsfiddle.net/579rob3j/1/
    Also, in your sample, you were using different versions of Wijmo for wijmo core, input and grid. Please make sure that all the CDN links added are for same version.
