Posted 17 November 2020, 5:21 pm EST - Updated 3 October 2022, 3:11 pm EST
I’m using flexgrid as a data grid component in a react application. Following is the flexgrid declaration.
<wjcGrid.FlexGrid itemsSource={this.state.data} initialized={this.initializeFlexSheet.bind(this)} >
<wjcGrid.FlexGridColumn header="ID" binding="id"></wjcGrid.FlexGridColumn>
<wjcGrid.FlexGridColumn header="Country" binding="country" dataMap={this.state.countryMap} ></wjcGrid.FlexGridColumn>
<wjcGrid.FlexGridColumn header="Product" binding="product"></wjcGrid.FlexGridColumn>
<wjcGrid.FlexGridColumn header="Amount" binding="amount" format="c" aggregate="Sum"></wjcGrid.FlexGridColumn>
<wjcGrid.FlexGridColumn header="Pending" binding="amount2" format="c2" aggregate="Sum"></wjcGrid.FlexGridColumn>
<wjcGrid.FlexGridColumn header="Discount" binding="discount" format="p1" aggregate="Avg"></wjcGrid.FlexGridColumn>
<wjcGrid.FlexGridColumn header="Active" binding="active" width={70}></wjcGrid.FlexGridColumn>
</wjcGrid.FlexGrid>
as you can see there is a check box column and drop down menu column in the grid.
I’m having an excel file import/export functionality bounded to this grid.
let fileInput = document.getElementById("importFile");
console.log("file content :"+fileInput.files[0]);
wjcGridXlsx.FlexGridXlsxConverter.loadAsync(this.flex, fileInput.files[0], { includeColumnHeaders: this.state.includeColumnHeader });
when come to the excel file import functionality content of the excel file is loading to the grid but drop down menus and check boxes are no longer displayed in corresponding grid cells. Instead only the values in excel file is displaying. Please refer the attachments
Following is the complete code
import "@grapecity/wijmo.styles/wijmo.css";
import "bootstrap.css";
import "./app.css";
import * as React from 'react';
import * as ReactDOM from 'react-dom';
import * as wjcCore from "@grapecity/wijmo";
import * as wjcGrid from "@grapecity/wijmo.react.grid";
import * as wjGrid from "@grapecity/wijmo.grid";
import * as wjcXlsx from "@grapecity/wijmo.xlsx";
import * as wjcGridXlsx from "@grapecity/wijmo.grid.xlsx";
import { getProductOrders } from "./data";
class App extends React.Component {
constructor(props) {
super(props);
this.state = {
data: getProductOrders(5),
fileName: "",
includeColumnHeader: true,
customContent: false,
//countryMap : ['US', 'Germany', 'UK', 'Japan', 'Italy', 'Greece']
countryMap : ['us', 'uk', 'japan']
render() {
console.log("data==="+this.state.data[0].country);
console.log("data==="+this.state.data[0].active);
return <div className="container-fluid">
<div className="row">
</wjcGrid.FlexGrid>
</div>
<div className="col-md-6 col-xs-12">
<div className="form-inline well well-lg">
<input type="file" className="form-control" style={{ width: '250px' }} id="importFile" accept="application/vnd.openxmlformats-officedocument.spreadsheetml.sheet, application/vnd.ms-excel.sheet.macroEnabled.12"/>
<button onClick={this.load.bind(this)} className="btn btn-default">Import</button>
{/* <div className="checkbox">
<label>
<input defaultChecked type="checkbox"/> Include Column Header
</label>
</div> */}
</div>
</div>
<button onClick={this.save.bind(this)} className="btn btn-default">Export</button>
<label>
</label>
</div> */}
<label>
<input v-model="customContent" type="checkbox"/> Custom Cell Content
</label>
</div> */}
</div>
</div>
</div>
</div>;
initializeFlexSheet(flex) {
this.flex = flex;
save() {
wjcGridXlsx.FlexGridXlsxConverter.saveAsync(this.flex, {
includeColumnHeaders: this.state.includeColumnHeader,
includeCellStyles: false,
formatItem: this.state.customContent ? this.state._exportFormatItem : null
}, "FlexGrid.xlsx");
load() {
//wjcGridXlsx.FlexGridXlsxConverter.load(this.flex, fileInput.files[0], { includeColumnHeaders: this.state.includeColumnHeader });
this.setState({
//data: getProductOrders(500)
//customContent: true,
//data: this.state.data
exportFormatItem(args) {
var p = args.panel, row = args.row, col = args.col, xlsxCell = args.xlsxCell, cell, color;
if (p.cellType === wjGrid.CellType.Cell) {
if (p.columns[col].binding === "color") {
//color = p.rows[row].dataItem['color'];
if (xlsxCell.value) {
if (!xlsxCell.style.font) {
xlsxCell.style.font = {};
xlsxCell.style.font.color = xlsxCell.value.toLowerCase();
else if (p.columns[col].binding === "active" &&
p.rows[row] instanceof wjGrid.GroupRow) {
cell = args.getFormattedCell();
xlsxCell.value = cell.textContent.trim();
xlsxCell.style.hAlign = wjcXlsx.HAlign.Left;
ReactDOM.render(<App />, document.getElementById('app'));
Please help me to resolve this problem.
Dasun
