Flexgrid filtering applies on a filtered data after cell edit ended
Posted by: theruler0000 on 25 October 2020, 3:02 am EST
    Posted 25 October 2020, 3:02 am EST
    Hi team,
    we are using wijmo 5.20172.334 version with angular.js. Issue is filter is applying after cell edit ended on an filtered data. How to stop that filter refresh or is there any other approach to stop filtering of data after cell edit ended.
  • Posted 26 October 2020, 12:14 am EST
    Hi Ananth,
    We have replied to your query on the forum post here:
    https://www.grapecity.com/forums/wijmo/issue-with-updating-values
  • Posted 27 October 2020, 2:36 am EST
    Hi Ashwin, Thank you for the reply. Can you provide me a guide how to upgrade the wijmo to latest or specific version…
    Thank you,
    Ananth Padmakar
  • Posted 27 October 2020, 5:53 am EST
    Hi Ananth,
    If you are using angularjs, then you must be using the CDN version of Wijmo. You will need to update the CDN links because the 17v2 versions use different links. You can find the links below:
    https://www.grapecity.com/wijmo/docs/GettingStarted/Referencing-Wijmo#deploying-wijmo-from-cdn
    You may run into some issues while upgrading because there are many changes done between your version and the latest version.
    You will also need to renew your license. You can contact the sales team at us.sales@grapecity.com for a renewal.
    Feel free to revert back to us with any issue related to the upgrade.
  • Posted 27 October 2020, 6:44 am EST
    Thank you for the info Ashwin.
  • Posted 29 October 2020, 1:59 am EST
    Hi Ashwin, can I use the wijmo trail version files in my project to try before renewal? I mean links of wijmo latest version.
  • Posted 29 October 2020, 2:02 am EST
    Hi Ananth,
    Yes, you can. If you are working on the localhost, then a simple watermark of evaluation will be displayed. But if you will publish the application, then a popup will be displayed when the page is loaded.
  • Posted 29 October 2020, 5:51 am EST
    Hi Ashwin, your reply helped me a lot and we tried New version in our local and its working great. We will renew our license. But one more thing we are facing issue in
    Turkish language. The below is the grid header with a checkbox. When we have changed the language in chrome settings, this checkbox disappears and showing select label instead of checkbox. How could this be solved?
  • Posted 29 October 2020, 5:52 am EST - Updated 3 October 2022, 3:18 pm EST
  • Posted 30 October 2020, 12:52 am EST
    Hi Ananth,
    Can you let me know how have you added the checkboxes in the header? Also, does the screenshot attached replicates your issue? What is the purpose of the checkbox in the header?
    Can you also provide a stripped-down sample that replicates your issue?
  • Posted 2 November 2020, 1:20 am EST - Updated 3 October 2022, 3:18 pm EST
    Sorry for the delay in response Ashwin, due to some medical emergencies. And here are the answers for your questions.
    Q: Can you let me know how have you added the checkboxes in the header?
    Ans: The below is the code how we implemented.
    Q: Also, does the screenshot attached replicates your issue?
    Ans: yes.
    The above image replicates the issue and the rectangled area shows where check box should appear. Instead it shows select label.
    Q: What is the purpose of the checkbox in the header?
    Ans: Purpose of header is to select call the checkboxes in that column.
  • Posted 2 November 2020, 7:17 am EST
    Hi Ananth,
    Please do not apologize for the delayed response.
    Can you try using the new BooleanChecker class added? Refer to the sample link below:
    https://stackblitz.com/edit/angularjs-ta5v2u
    Let me know if the issue happens with this also.
    API: https://www.grapecity.com/wijmo/api/classes/wijmo_grid_selector.booleanchecker.html
