FlexGrid in component
Posted by: akhabarov on 1 April 2020, 8:01 pm EST
  • Posted 1 April 2020, 8:01 pm EST
    I’ve created shared component which use flexgrid.
    The component declared in shred.module
    app.module for one app include the shared.module and also in imports it decared WjGridModule.
    When I run the app I’m getting following error: Can’t bind to ‘itemsSource’ since it isn’t a known property of ‘wj-flex-grid’.
    Any ideas please what can be reason for the error and how to fix it?
  • Posted 2 April 2020, 6:59 am EST
    We were unable to replicate the issue at our end. Please refer to the sample attached that we used to replicate the issue.
    Can you please let us know whether we are missing something in order to replicate the issue?
    flexgrid module.zip
  • Posted 2 April 2020, 11:24 am EST
    I’ve updated Wijmo 5.20193.637 to 5.20201.663 and now I’m getting the error: Template parse errors:
    It’s not related to shared component. Now I’m having this error in all components using FlexGrid.
    The reason why I updated it to get class Selector for functionality like in example https://www.grapecity.com/wijmo/demos/Grid/Selection/CheckboxSelection/angular
    Can I have the same functionality, checkboxes on rowheader, with version 5.20193.637?
  • Posted 2 April 2020, 11:32 am EST
    I’m looking for exactly the same functionality 3 levels of groups and when you click on group header checkbox it will select all rows in the group
  • Posted 2 April 2020, 12:03 pm EST
    No, sorry it’s not update, it is because of component in shared module.
    I just removed the component from shared module and FlexGrid in regular components start working.
    I’ll check your example against mine and let you know.
  • Posted 2 April 2020, 1:22 pm EST
    Ok, solved, thanks a lot!
  • Posted 2 April 2020, 11:56 pm EST
    I am glad that you were able to resolve the issue. Can you please let me know whether the Checkbox selection is working in your application or do you require any further assistance.
  • Posted 3 April 2020, 10:59 am EST
    Everything works fine, thank you
